Forum Home › Forums › Understanding the Software › Log in web page
- This topic has 22 replies, 4 voices, and was last updated 5 years, 6 months ago by
May 30, 2019 at 10:17 am #5496
scadarapid
ParticipantHi.
If I do not want to log in web page.
How can I do.Thank you so much.
May 30, 2019 at 1:54 pm #5499
Do you mean to log in automatically?
May 31, 2019 at 5:49 am #5500scadarapid
ParticipantHi.
Yes
Thank you so much
May 31, 2019 at 5:51 am #5501scadarapid
ParticipantLog in without fill user and password.
How can I do.
Thank you so much.
May 31, 2019 at 1:41 pm #5502
MikhailModeratorTry this plugin.
It logs in as the first user in the Users table.May 31, 2019 at 1:41 pm #5503
MikhailModeratorUse this link to open your web app:
http://localhost/Scada/AutoLogin.aspxJune 28, 2019 at 8:26 am #5626scadarapid
ParticipantHi.
Could you tell me the step how to use please.Thank you so much.
June 28, 2019 at 3:05 pm #5628
Install as usual. Then open the web app by http://localhost/Scada/AutoLogin.aspx
July 12, 2019 at 9:15 am #5695gasin
i try to do as your mention. after that i found error occur on screen. it show message error to update scheme data and i see all graphic did not show value.
it’s look like graphic can not connect to database.
how can i solve it?
July 12, 2019 at 4:16 pm #5698
Please provide a screenshot.
July 17, 2019 at 5:39 am #5718scadarapid
ParticipantHi.
I tried the PlgAutologin but it did not work now.
I have noticed that when I change the file name Web.config in the ScadaWeb(I copy from PlgAutologin folder and directly put it on the ScadaWeb folder) then, It made (Error updating current data Error, updating hourly data)
I have noticed the file Web.config of PlgAutoLogin and normal Web.config are different.
so How we solve the Error Updating data on the scheme.
when I use the web.config of PlgAutoLogin. I got this error.
https://www.img.live/images/2019/07/17/150215.jpg
https://www.img.live/images/2019/07/17/150214.jpgThank you so much.
July 17, 2019 at 11:11 am #5722gasin
Participantnow, i’ve problem with autologin,too.
before i add autologin to scadaweb folder, everything work fine.
after i add autologin to scadaweb folder and try to access website via address http://localhost/scada/login.aspx , i can pass login padge but it show error like this
https://1drv.ms/u/s!Ah3lJWvSyxVOgvcCAlGYfk_y6Xc4IA
and when i try to access website to be autologin like this http://localhost/scada/autologin.aspx , it show error like this
https://1drv.ms/u/s!Ah3lJWvSyxVOgvcBOsJJntEUNlbZHw
so, how can i solve this. please suggest.
July 17, 2019 at 1:37 pm #5729
MikhailModeratorI have noticed the file Web.config of PlgAutoLogin and normal Web.config are different.
You should restore the existing Web.config.
Try this update of Auto Login Plugin. It requires Webstation 5.0.8.0 or higherJuly 17, 2019 at 1:39 pm #5730
MikhailModeratorafter i add autologin to scadaweb folder and try to access website via address
What version of Webstation do you use?
July 18, 2019 at 5:37 am #5732scadarapid
ParticipantHi.
I use Webstation 5.0.7.0Now, It works. I did not change the Web.config, I use the Web.config of RapidScada.
I have to clear chrome cache. then I open the chrome and use “http://localhost/Scada/AutoLogin.aspx”Thank you so much.
