Forum Home › Forums › Installation Issues › SCADA-Web Installation › localhost/scada/
- This topic has 23 replies, 5 voices, and was last updated 7 years, 3 months ago by
March 23, 2018 at 3:37 pm #3345
J07CR
ParticipantHallo,
Iam trying to connect to localhost/scada/ so i can see my scheme editor that i made. But this localhost page cant be found.
any suggestions ? and yes i allready tried http://127.0.0.1/scada/
March 23, 2018 at 5:11 pm #3346
Try http://localhost/ If you don’t see IIS welcome page, you should install IIS as written here http://doc.rapidscada.net/content/en/installation-and-run/software-installation.htmlIf IIS is already installed, may be you should fix it.
March 23, 2018 at 6:26 pm #3357J07CR
Participantyes IIS is installed and yes i can see the IIS welcome page
March 26, 2018 at 12:50 pm #3360
MikhailModeratorOpen IIS management console and check if ScadaWeb application exists. It should be displayed as a subnode of Default Website.
Does C:\SCADA\ScadaWeb directory exist?
March 26, 2018 at 2:06 pm #3364J07CR
ParticipantNo it doesn’t exist, but i have managed to install this manually . Like it is describe in the documentation of the rapid Scada. So now i can open the localhost/scada/
thank you
March 27, 2018 at 3:21 pm #3366
April 26, 2018 at 10:31 am #3627Kirth
ParticipantHello !
I installed Rapid SCADA for a university project. “Localhost/scada/” do not work. I tried all the links and the methods of the Rapid SCADA forum, but the page always shows error on different computers. I have the downloaded and the installed the files as per the documentation. After, i followed the tutorials on YouTube ( Rapid SCADA channel) the file web station doesn’t appear. I put you as an attachment the error message. There is a few days everything worked correctly, so I don’t understand the reason.Thank you for your help,
April 26, 2018 at 1:45 pm #3628
What is displayed by http://localhost/ ?April 27, 2018 at 7:35 am #3630Kirth
Participanthi,
It displays ERROR 500 This page doesn’t work “Impossible to handle this demand(request) via localhost at the moment.” And there is a button “refresh”April 27, 2018 at 3:45 pm #3631
It means that IIS doesn’t work. You should check the installed components. Also check the port 80, may be it is used by another application.May 2, 2018 at 10:07 am #3658Kirth
ParticipantI tried everything and it doesn’t work.
May 3, 2018 at 3:19 pm #3664
MikhailModeratorI can try to fix it using remote connection if you OK with the commercial service. For pricing, please send a request to this email.
November 16, 2018 at 11:21 am #4605
Hennie_KotzeParticipantI also have a problem with my Localhost…
Explorer says: “This site cant be reached”.
I followed the “turn windows features on or off” exactly like its indicated, but it still does not work.
I checked the default pool is .NET V4.0 and an integrated pipeline mode.
I made sure no other processes are using port 80.I can successfully connect with my device, and even send commands, but my webstation does not start up…
I uninstalled and re-installed the software twice already.
Here is my install log:
Start Rapid SCADA 5.5.3 installation 11/16/2018 12:55:30 PM
Create directory C:\SCADA\
Create directory C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SCADA\Install Server application
Unzip files from ScadaServer.zip
Create shortcut Server
Install service ScadaServerService
Installation of Server application has completed successfullyInstall Communicator application
Unzip files from ScadaComm.zip
Create shortcut Communicator
Install service ScadaCommService
Installation of Communicator application has completed successfullyCheck the configuration of Internet Information Services (IIS)
Go to
Control Panel > Programs > Turn Windows features on or off
and make sure that WCF Services > HTTP Activation feature is installed for .NET Framework 4+,
whereas the components for .NET Framework 3.5 are switched off
Check Windows Communication Foundation (WCF)
Register ASP.NET
Install Webstation application
Unzip files from ScadaWeb.zip
Selected application pool: DefaultAppPool
Register web application Scada
Create shortcut Webstation
Installation of Webstation application has completed successfullyCheck Microsoft SQL Server Compact 3.5
Unzip files from ScadaAdmin.zip
Create shortcut Administrator
Installation of Administrator application has completed successfullyInstall Table Editor application
Unzip files from ScadaTableEditor.zip
Create shortcut Table Editor
Installation of Table Editor application has completed successfullyInstall Scheme Editor application
November 16, 2018 at 5:21 pm #4607
MikhailModeratorAm I understand you correcly: When you open this link http://localhost on your server, you get “This site cant be reached”?
You should reinstall Rapid SCADA. This issue relates to IIS.
What OS do you use?
Try this advice.November 16, 2018 at 5:30 pm #4609
Hennie_KotzeParticipantYes, that is correct. If i try to open http://localhost, it says the site cant be reached.
I did un-install the software and restarted my PC. I installed the software again, and restarted the PC. I did this twice.
In my previous message i included my install log file that indicates the software installed correctly.
The Re-install does not work.
I am using Windows 10
