Forum Home › Forums › Installation Issues › Installation has completed with errors
- This topic has 19 replies, 3 voices, and was last updated 7 years, 10 months ago by
jeff.
April 17, 2018 at 7:06 am #3521
jeff
ParticipantI’m facing some errors during installation, the server service and communicator installation failed due to some errors.
The system stated :
“ScadaServerService hasn’t been installed. Installation of Server application has completed with a error.”
“Service ScadaCommService hasn’t been installed. Installation of Communicator application has completed with a error.”Please advise me on this issues.
April 18, 2018 at 4:39 pm #3530
MikhailModeratorPlease make screenshots of the following folders
C:\SCADA\ScadaComm
C:\SCADA\ScadaServer
and paste links to them here.If the folders are not empty, execute svc_install.bat from command line as administrator. Make screenshots of the output.
April 19, 2018 at 1:33 am #3539jeff
Participanthttp://tinypic.com/r/1zl3m09/9
This reply was modified 7 years, 10 months ago by
jeff.
April 19, 2018 at 1:35 am #3541jeff
ParticipantApril 19, 2018 at 11:55 am #3548
MikhailModeratorAll required files are located in the folders. So you can install services by executeingsvc_install.bat from command line as administrator.
April 19, 2018 at 6:34 pm #3557Pieter
ParticipantI had same problem once. Turned out I did not switch all the right features ON.
Instructions is in the install folder.April 20, 2018 at 6:22 am #3559jeff
ParticipantThank you very much. I can use rapid scada now. but when I open the SCADA administrator, I cant understand the language and not same with the video I watched.
Please advise. Thank you.
April 20, 2018 at 10:15 am #3560
MikhailModeratorUse SetCulture utility to change the application culture to en-GB.
Also you can click Настройки (5th) then Язык (2nd) and choose English.
Settings are applied after app restart.April 20, 2018 at 10:15 am #3561
MikhailModeratorWhat is your default Windows language?
April 23, 2018 at 3:20 am #3582jeff
ParticipantHi Mikhail, my default windows language is english.
I tried the 2 methods you suggested, I installed the set culture but it can’t work. And for the setting side I can’t find the english.
Please advise.
jeff.
April 23, 2018 at 6:35 am #3584
The first one is English (en-GB). After choosing, press OK and restart Administrator and other applications.
Does it help?April 23, 2018 at 9:35 am #3592jeff
I tried it many times, I not sure is that the software problem or what because it will come out the below as the attached image.
April 23, 2018 at 2:03 pm #3598
MikhailModeratorThis is really strange.
Could you check C:\SCADA\ScadaAdmin\ScadaAdmin.err ?You just need to add the record to the registry:
https://imgur.com/a/zBgPeX3April 23, 2018 at 2:04 pm #3599
MikhailModeratorWhat Windows version do you use?
April 24, 2018 at 2:57 am #3606jeff
ParticipantI am using windows 7 professional with 64-bit operating system.
