Events trigger and colors
Forum Home Forums Understanding the Software Events trigger and colors
Viewing 15 posts - 1 through 15 (of 21 total)
  • #4463
    ngiussani
    I have encounter an issue when trying to custom some events. For instance, if I’m recording an event of an emergency stop, ON should be the “alarm” condition, wich is usually associated with red color, instead of green, as it is shown on the events table. Is there some way to change that for a particular event?
    Also, is there a way of recording only one condition of the event?
    Thanks in advanced.
    #4470
    Event color depends on status color of the input channel. I mean you should change colors of Off-On values.
    Create your own record in the Units table, for example,
    Normal; Alarm; –
    And use formulas for setting the status of the input channel:
    Cnl; Cnl > 0 ? 114 : 13
    #4471
    Currently no. Some modifications should be done to implement it.
    #4479
    ngiussani
    Mikhail,
    Once again, thank you. Very clear and simple explanations.
    #4480
    ngiussani
    I’m sorry to bother you again, but it doesn’t seem to be working with Discrete type (On-Off) and I can’t change the type, as it is a DI in MODBUS. The only way I can think is to make a calculated signal. Is that the only soultion?
    P.S.: I was refering to this table view:
    Events
    Imageo of Events View
    • This reply was modified 7 years, 2 months ago by ngiussani.
    #4485
    Please provide a screenshot of your configuration related to this issue.
    #4486
    ngiussani
    Mikhail,
    Once again, thank you. I was making something wrong with the formulas. The working formula is:
    Cnl; (Cnl == 1.0) ? SetStat(1026, 15) : SetStat(1026, 11)
    Still, colors in the events table (the one located below the view, with date and time) are shown like the screenshot above: red for OFF, green for ON, wich is the opposite of what I need for the Emergency Stop case.
    #4497
    See my previous message.
    #4500
    ngiussani
    Hi Mikhail,
    I’m not sure what’s the screenshot you’re asking for. What configuration are you refering to?
    #4504
    Input channels, units that are related to the issue.
    #4507
    ngiussani
    OK. I’m sorry I wasn’t clear. I solved that issue. Even thou, here’s the screenshot:
    Input Configuration
    Input Configuration
    I’m still struggling with colors on the Events table. I don’t know if there is anything I can do at all or if it’s an implementation matter, and is that way.
    Events Colors
    Event Colors
    Thanks again.
    #4509
    Thank you for the images.
    You need to open the Units table in Administrator. And create a new row with a new unit. Do at as written above. Then set the new unit for your input channel.
    #4512
    ngiussani
    Mikhail,
    I’m sorry. I missread your answer. I don’t know why I thought I had to change events, instead of units.
    That’s working like a charm.
    Thanks again!
    #4513
    Cool!
    May I ask you about the forum, do you receive notifications when I answer in the topic? Do they work well?
    #4515
    ngiussani
    Mikhail,
    Yes. I do receive notifications. Sometimes I just need to remind to tick the box, which I haven’t did somteimes before, but the work well.
