Forum Home › Forums › Uncategorized Issues › Daily Archive
- This topic has 30 replies, 3 voices, and was last updated 1 year, 6 months ago by
January 12, 2025 at 9:37 pm #15974
Hcinarli
ParticipantHello, I created a special 3-minute archive type for myself for archive recording and configured the table editor accordingly, it kept the 3-minute data periodically, but the same process for daily data failed to record data every 24 hours, I shared screenshots, what is the reason or what should I do, how should I configure the table and archive properties?
January 13, 2025 at 11:42 am #15977
MikhailModeratorScreenshots are not available. Please fix them.
January 13, 2025 at 12:48 pm #15978Hcinarli
ParticipantJanuary 14, 2025 at 5:19 am #15979Hcinarli
ParticipantHello, were you able to check?
Exactly what I want to do is to save and list the data I read from the modbus protocol on a daily basis, I want to do the same operations for daily data as for hourly data in the table editor, I explained the operations I did in #15974 thanks.
January 14, 2025 at 8:24 am #15982
manjey73ParticipantIt’s not entirely clear what you want. Should I write the amount for that day in the cell of the Daily Database, or just the current value of the specified day?
January 14, 2025 at 8:54 am #15983Hcinarli
ParticipantI will need both in the future, but as an example for now
January 14, 00.00 Value
January 15, 00.00 Value
January 16, 00.00 valueI would be glad if it is possible to learn both in the form of periodically recording the instantaneous read value and displaying it in the daily data table and displaying the amount of the value read within 1 day in the column of the relevant day.
January 14, 2025 at 8:59 am #15984
manjey73ParticipantShare the table settings, how did you create the column in just one day?
It’s interesting to try. Perhaps the regular tables plugin itself can’t do this and you need another plugin?January 14, 2025 at 9:31 am #15986
MikhailModeratorOK, the settings are clear now. What actual result do you get in a table view?
January 14, 2025 at 10:41 am #15987Hcinarli
ParticipantIn the channels where I want to save the daily data, the daily data from the archive mask field is marked, the table settings are as in the picture I sent and I added the channels I want to see the daily data, the table view comes as 1 day ago and 00, but it does not save the data, I cannot see the fields of the next days in the table. Only the instant values of the chanels I added come.
This reply was modified 1 year, 6 months ago by
Hcinarli.
January 14, 2025 at 10:55 am #15990
manjey73ParticipantThe server is running in UTC time, your time corresponds to UTC, maybe that’s the reason?
Can you upload a primitive project with settings?.sometimes I don’t understand how it works either, I have to constantly calculate the time in my head 🙂
January 14, 2025 at 9:07 pm #15997Hcinarli
ParticipantI have checked the UTC settings, I have also sent screenshots, and the sample project is also attached, and the table name I want to configure is “Günlük.tbl” I would appreciate it if you can check and return back.
Screenshots
https://ibb.co/Sr49STj
https://ibb.co/GczdZskProject
January 15, 2025 at 5:56 am #15999
manjey73ParticipantThe project is not downloading. It leads nowhere. Can you put it on some kind of Google drive and give it a link?
January 15, 2025 at 11:02 am #16003
MikhailModeratorWhat actual result do you get in a table view?
I mean a screenshot of the web page.
January 15, 2025 at 6:10 pm #16006Hcinarli
ParticipantI left a link to Google drive, I would be happy if you can check and return, thanks
https://drive.google.com/file/d/1Oz7IkWQlKfkohyWVvvDU98ZYuDhcYCvY/view?usp=drivesdk
January 15, 2025 at 8:37 pm #16007
manjey73ParticipantIt seems to me that this is impossible. Most likely, this is how the regular table plugin works. Which can show columns of the selected time period only for one day, while reading archives only from the Sentinel.
That is, in principle, he will not be able to make 30 or 31 columns based on the number of days in the current month. (or 28, 29 if the month is February)
