Chart Pro with application error
Forum Home › Forums › Installation Issues › Chart Pro with application error
  • #7245
    kcks66
    Hi Mikhail,
    I have installed Chart Pro and extracted them to the directories. Changed the Chart Plugin to Chart Pro, saved and downloaded into Project. I get this error:
    Application Error
    Details:
    Method not found: ‘!!0 Scada.Web.WebUtils.GetParamAsEnum(System.Collections.Specialized.NameValueCollection, System.String, !!0)’.
    Webstation 5.1.0.0
    Chart Pro 5.1.0.0
    Is there any steps that I missed?
    #7246
    This error caused by version mismatch.
    You have the latest Chart Pro, but Webstation looks outdated.
    Could you check the timestamp of C:\SCADA\ScadaWeb\bin\ScadaWebCommon.dll file?
    We have a minor bug that after updating Webstation, it’s version number still 5.1.0.0. That’s why it’s better to check file age.
    #7247
    kcks66
    Hi Mikhail,
    My PC ScadaWebCommon.dll timestamp is 2020/1/28.
    #7251
    You should update Rapid SCADA to version 5.8.1 to fix this issue.
    #7256
    kcks66
    Hi Mikhail,
    I update Rapid SCADA to version 5.8.1. However, I still got error:
    Application Error
    Details:
    The specified string is not array of integers.
    #7257
    Try clearing browser cache. If it doesn’t help, please provide a link to a screenshot with the error.
    #7261
    kcks66
    Hi Mikhail,
    The chart is working well now after cleared browser cache.
    #8673
    hethongscada62
    Dear Mr.Mikhail,
    The registration key for Chart Pro was configured. That seems is working in Web well. But the software have not processed the Chart.
    https://ibb.co/19ZFhpg
    https://ibb.co/J72mskk
    Could you let me know where is wrong? Where can i check?
    Thanks and best regards
    From Han Hoang
    #8674
    hethongscada62
    Dear Mr.Mikhail,
    https://ibb.co/Zm08Msv
    https://ibb.co/fYKCdgr
    From Han Hoang
    #8675
    You need to select Chart Pro in the configuration of the web application.
    #8681
    hethongscada62
    Hello Mr.Mikhail,
    Yes, all keys were selected in the configuration of the web application.
    https://ibb.co/T4q9p6q
    #8692
    In web browser open http://localhost/scada/plugins/Config/WebConfig.aspx, select “Chart plugin”, save configuration and download it into the project as written in the manual.
    #8720
    hethongscada62
    Dear Mr.Mikhail,
    Chart Pro Plugin was selected, but can not get the result.
    Some screenShot are following:
    https://ibb.co/DktzQTb
    https://ibb.co/SQmYbTH
    https://ibb.co/M2j2v3T
    Where is wrong?
    Where have i check?
    #8721
    You should provide write access to the configuration directory and configuration file:
    C:\SCADA\ScadaWeb\config\
    C:\SCADA\ScadaWeb\config\WebSettings.xml
    or
    /opt/scada/ScadaWeb/config/
    /opt/scada/ScadaWeb/config/WebSettings.xml
    #8722
    If you already did it, repeat.
