Sending email by using Gmail sudden fail
Forum Home › Forums › Understanding the Software › Sending email by using Gmail sudden fail
Viewing 15 posts - 1 through 15 (of 40 total)
  • #10344
    kcks66
    Hi Mikhail,
    I am using email function configured by using Gmail smtp so far so good until recent Google announced “Less Secure App Access” option was no longer available. I set the Less Secure App Access to ON and enable IMAP previously. Now you can see from the below image that suddenly Gmail reject Rapid SCADA to access my google account.
    https://ibb.co/tcDB9hQ
    Rapid SCADA email configuration image as below.
    https://ibb.co/C5NNKMT
    Pls advice for is there anything I can do to have the email sending function resume working fine?
    #10345
    As I understand, Google does not allow 3rd party application to send emails any more.
    You should use another email service.
    For example, in my country https://yandex.com is popular.
    Mail servers may use various server host and port, different than Google. Check their manuals.
    • This reply was modified 4 years, 4 months ago by Mikhail.
    #10351
    kcks66
    Hi Mikhail,
    Noted that I should use another email service. I setup an account from yandex email service as per your suggest.
    However, I couldn’t make the email sender work; I got error message:
    https://ibb.co/bvNmBcZ
    My email sender setting:
    https://ibb.co/6BrfbGS
    Pls advice for is there anything else I need to do?
    #10352
    Try port 25
    #10355
    kcks66
    Hi Mikhail,
    Port 25 gave another new error message:
    Error sending email to cho.keat.seong@gmail.com: Bad sequence of commands. The server response was: 5.5.4 Error: send AUTH command first. 1655372643-0Hlz4rXRDy-i3MmpLEF
    Pls advice and thank you.
    #10358
    Check the settings:
    https://ibb.co/hKd7VfT
    #10361
    kcks66
    Hi Mikhail,
    Thanks for the Yandex setting. I tested by using Communicator Email Command, it went through but Yandex treat it as spam.
    Error sending email to cho.keat.seong@gmail.com: Transaction failed. The server response was: 5.7.1 Message rejected under suspicion of SPAM; https://ya.cc/1IrBc 1655471924-o4ZxzWO5VS-IgMqIU61
    #10362
    May be you should try sending email with simple text.
    I suggest to contact Yandex technical support.
    #10383
    kcks66
    Hi Mikhail,
    Email was successfully sent out by simple text.
    #10494
    PVO
    I have a similar problem as the one mentioned in this topic.
    Since gmail no longer emailing without verification, I tried to configure yandex mail account.
    Server host: smtp.yandex.com
    Port: I tried both 25 and 465
    User: my yandex e-mailadres (I tried with and without @yandex.com)
    SSL is ON.
    I always get a time out when trying to send an e-mail…
    Kr,
    Philippe
    #10498
    Users say that you should create an external application in Yandex and set password for it. Translate this post.
    #12062
    hethongscada62
    Dear Mr. Mikhail,
    The Email driver have been installed in Windows for testing. It works perfectly when I send email directly via command of device. Then this Email driver installed in Raspberry Pi4.
    https://imgbb.su/image/xJK1V6
    It not works via Automatic Control module.
    https://imgbb.su/image/xJKrDE
    https://imgbb.su/image/xJKPhS
    May be the configure of Automatic control is wrong, isn’t?
    https://imgbb.su/image/xJT4VC
    Could you check and let me know.
    Thanks a lot
    Sorry I wasted your much time
    Han Hoang
    #12065
    In the communication line log, there is an error on loading the Email Driver settings.
    You should check that the driver version on Windows and on RPi are the same. Use the up to date version.
    #12068
    hethongscada62
    Dear Mr. Mikhail,
    Thank you for your reply,
    After checking the date version, reboot a RPi. The status of device that seems is normal, but after refreshing RPi, the status of device is error.
    https://imgbb.su/image/xgEHFw
    https://imgbb.su/image/xgEbQc
    https://imgbb.su/image/xgE3IQ
    https://imgbb.su/image/xgENDl
    Where is wrong?
    Thanks a lot
    Han Hoang
    #12069
    victorlam
    Hello Han Hoang,
    I would like to learn to use email sending to remind the user.
    Can you help to share some settings how you can configure here?
    Thanks!!
    Victor
