Forum Home › Forums › Understanding the Software › Get data from excel into DAT files
- This topic has 24 replies, 3 voices, and was last updated 5 years, 4 months ago by
January 10, 2021 at 5:23 am #7960
kcks66
ParticipantHi Mikhail,
Good day to you. I want to copy/import my historical data from excel into Rapid SCADA newly created real/calculated real channels. Then save into DAT files. Pls advice for how to do this.
My excel historical sample data:
https://ibb.co/rtSkxZ9Thank you.
January 11, 2021 at 10:18 am #7965
A utility should be developed to import data. Otherwise, only manual input one by one value is available.
January 11, 2021 at 12:53 pm #7969kcks66
I could try the manual input one by one value method. Pls advice for how to do it?
January 12, 2021 at 2:17 pm #7987
Just find in Administrator – Server – Generator. Using Generator you can set any value of any input channel.
January 14, 2021 at 6:23 am #8020kcks66
I tried to manual generate value into Archive Data, as below:
https://ibb.co/vXMytQhI can see the value is generated, as below:
https://ibb.co/8rfRVbzHowever, I cannot see from the Chart, as below:
https://ibb.co/VMVH7KnIs there anything I missed out? Pls advice and thank you.
January 14, 2021 at 9:37 am #8022
manjey73ParticipantStatus write “2”
January 14, 2021 at 1:39 pm #8026
MikhailModeratorStatus write “2”
Or any other positive status. All available statuses are listed in the Event types table.
January 15, 2021 at 5:49 am #8028kcks66
ParticipantHi Mikhail & manjey73,
I succeed generated value and show on Chart after Status wrote 2.
There were one value generated at 00:00 and another value generated at 01:00. Is there any possibility to join the line in between them?
January 15, 2021 at 7:48 am #8029
manjey73ParticipantMikhail promised to implement this in the next version of Scada. Now you can try using Grafana for these purposes
January 15, 2021 at 1:08 pm #8031
MikhailModeratorThe is a parameter of Webstation, named Chart Gap. It defined time period that is connected by a line. You should create data points more often than parameter value.
January 16, 2021 at 3:16 am #8037kcks66
It is worked after I changed the ChartGap to 4,000 sec.
https://ibb.co/R2LZXkBThank you.
January 16, 2021 at 3:23 am #8038kcks66
I have new question to ask; can I generate value into new DAT file with date earlier than recorded?
I want to generate value into channels for date 2018 Jan 1 as example.
Thank you.January 16, 2021 at 9:42 am #8041
manjey73ParticipantIf you create the parameter in the same way as you checked this example, the file will be created ? If yes, try using the API
January 17, 2021 at 8:30 am #8046
MikhailModeratorYes. A new file will be created.
January 18, 2021 at 3:38 am #8054 -
