Daily Archive
Forum Home Forums Uncategorized Issues Daily Archive
Viewing 15 posts - 1 through 15 (of 31 total)
  • #15974
    Hcinarli
    Hello, I created a special 3-minute archive type for myself for archive recording and configured the table editor accordingly, it kept the 3-minute data periodically, but the same process for daily data failed to record data every 24 hours, I shared screenshots, what is the reason or what should I do, how should I configure the table and archive properties?
    https://ibb.co/X37WNK4
    https://ibb.co/C2KNb6H
    #15977
    Screenshots are not available. Please fix them.
    #15978
    Hcinarli
    Hcinarli
    Hello, were you able to check?
    Exactly what I want to do is to save and list the data I read from the modbus protocol on a daily basis, I want to do the same operations for daily data as for hourly data in the table editor, I explained the operations I did in #15974 thanks.
    https://ibb.co/qJqGRTz
    https://ibb.co/jzrPV11
    #15982
    It’s not entirely clear what you want. Should I write the amount for that day in the cell of the Daily Database, or just the current value of the specified day?
    #15983
    Hcinarli
    I will need both in the future, but as an example for now
    January 14, 00.00 Value
    January 15, 00.00 Value
    January 16, 00.00 value
    I would be glad if it is possible to learn both in the form of periodically recording the instantaneous read value and displaying it in the daily data table and displaying the amount of the value read within 1 day in the column of the relevant day.
    #15984
    Share the table settings, how did you create the column in just one day?
    It’s interesting to try. Perhaps the regular tables plugin itself can’t do this and you need another plugin?
    #15986
    OK, the settings are clear now. What actual result do you get in a table view?
    #15987
    Hcinarli
    In the channels where I want to save the daily data, the daily data from the archive mask field is marked, the table settings are as in the picture I sent and I added the channels I want to see the daily data, the table view comes as 1 day ago and 00, but it does not save the data, I cannot see the fields of the next days in the table. Only the instant values of the chanels I added come.
    https://ibb.co/zstZ4cb
    • This reply was modified 1 year, 8 months ago by Hcinarli.
    #15990
    The server is running in UTC time, your time corresponds to UTC, maybe that’s the reason?
    Can you upload a primitive project with settings?.
    sometimes I don’t understand how it works either, I have to constantly calculate the time in my head 🙂
    #15997
    Hcinarli
    I have checked the UTC settings, I have also sent screenshots, and the sample project is also attached, and the table name I want to configure is “Günlük.tbl” I would appreciate it if you can check and return back.
    Screenshots
    https://ibb.co/Sr49STj
    https://ibb.co/GczdZsk
    Project
    https://dosya.co/wsssdem0h9cq/Project.rar.html
    #15999
    The project is not downloading. It leads nowhere. Can you put it on some kind of Google drive and give it a link?
    #16003
    I mean a screenshot of the web page.
    #16006
    Hcinarli
    I left a link to Google drive, I would be happy if you can check and return, thanks
    https://drive.google.com/file/d/1Oz7IkWQlKfkohyWVvvDU98ZYuDhcYCvY/view?usp=drivesdk
    #16007
    It seems to me that this is impossible. Most likely, this is how the regular table plugin works. Which can show columns of the selected time period only for one day, while reading archives only from the Sentinel.
    That is, in principle, he will not be able to make 30 or 31 columns based on the number of days in the current month. (or 28, 29 if the month is February)
