ModDBExport
Forum Home › Forums › Uncategorized Issues › ModDBExport
Viewing 7 posts - 31 through 37 (of 37 total)
  • #5038
    but how to doit?
    See T-SQL manual. Also we can develop scripts for you for a fee.
    #5041
    aluy069
    i performed in SQL 2017
    SELECT [DateTime],
    case when cnlnum = 22 then val else 0 end as Modelo,
    case when cnlnum = 26 then val else 0 end as Q,
    case when cnlnum = 29 then val else 0 end as Efici,
    case when cnlnum = 30 then val else 0 end as Disp,
    case when cnlnum = 32 then val else 0 end as Turno,
    case when cnlnum = 58 then val else 0 end as OEE,
    case when cnlnum = 65 then val else 0 end as Run,
    Stat
    FROM CnlData
    where CnlNum in (22,29, 30, 26,58,32,65) AND stat = ‘1’
    it almost do what i need from SQL server but, i just need to send those CnlNum (22,29, 30, 26,58,32,65) to the SQL2017 instead all values cor CnlNum.
    I need to do something in the SCADA server like this:
    — Insert current data CnlDataLS
    INSERT INTO CnlDataLSt (DateTime, CnlNum, Modelo, Calidad, Eficiencia, Disp, Turno, OEE, Run, Stat)
    VALUES (@dateTime, @cnlNum, @Val(22), @Val(29), @Val(30), @Val(26), @Val(58), @Val(32), @Val(65), @stat)
    my question in what should be the arguments for “INSERT INTO CnlDataLSt” and “VALUES”
    May I explain myself?
    #5051
    An INSERT statement executes for each channel separately.
    That’s why the default expression is simple
    INSERT INTO CnlData (DateTime, CnlNum, Val, Stat)
    VALUES (@dateTime, @cnlNum, @val, @stat)
    You have to change it to executing a stored procedure. Example for Postgres
    SELECT my_schema.proc_cur_data(@cnlNum, @val, @stat);
    And then perform filtering in the stored procedure my_schema.proc_cur_data.
    #5076
    aluy069
    Sorry but i dont know what you mean with “Example for Postgres”
    #5083
    I mean that the SQL syntax of my example is for Postgres.
    #5092
    aluy069
    Give me a quote to do the programation necesarely to:
    Send the data to SQL 2017 sever using db export to construct a table with the cnlnum I choose in the same line, also I beed timestamp and status
    The table headers in sql should look like:
    id | time | quality | oee | model | disp | stat
    I need when the dbexport send the data to sql send all colloms of the row at the same time
    tanks
    #5098
    Please write the request to info@…org and I will prepare a quote.
