Forum Home › Forums › Installation Issues › SCADA-Web Installation › Webstation issues on Win11
- This topic has 18 replies, 5 voices, and was last updated 11 months, 4 weeks ago by
August 29, 2024 at 5:18 pm #15265
Jose_1
ParticipantI just installed RapidScada 6.3.0. I followed all the steps shown in https://www.youtube.com/watch?v=dEJJ0waFzTk but couldn’t be successful in launching the webserver application.
When I access the ‘http://localhost:10008/’, I couldn’t see ‘SCADA’ page there.Can you help me to fix it, please? I already checked my IIS manageer and it looks like this:
https://drive.google.com/file/d/1qN8Jg1Q0pf0o4_P0y73375WThm6ykXol/view?usp=sharing
August 30, 2024 at 12:01 pm #15266
MikhailModeratorPlease expand the Sites node and make a new screenshot.
Also make a screenshot similar to this.August 30, 2024 at 1:28 pm #15268Jose_1
ParticipantSure, thank you for your prompt response, Mikhail.
sites node:
https://drive.google.com/file/d/1l-nfTVu6bnbG1vJNhWc6CiAWQAIpGsGU/view?usp=sharingmodules:
https://drive.google.com/file/d/1Gt84yadSl8czi9yZ5ds8B3nDA-g36HK6/view?usp=sharingSeptember 2, 2024 at 3:13 am #15270
showmustgoonParticipantIt seems like your module is missing the AspNetCoreModuleV2.
I recommend trying to reinstall or repair the ASP.NET Core Runtime.
The issue might be related to the installation order—sometimes the ASP.NET Core Runtime doesn’t correctly detect the IIS installation, leading to the absence of this module.
I’ve encountered this issue frequently in my own deployment scripts, so I usually force a repair of the ASP.NET Core Runtime after the initial installation to resolve it.September 2, 2024 at 6:33 am #15272Jose_1
ParticipantHi, showmustgoon
Thank you very much, but I tried reinstalling and repairing ASP.NET Core Runtime but it didn’t work… any other advice, please?September 2, 2024 at 6:55 am #15273
showmustgoonParticipantMake sure that the AspNetCoreModuleV2 is already present in your module. It would be best if you could provide a screenshot of the error encountered when accessing the website.
September 2, 2024 at 9:26 am #15274
MikhailModeratorMake sure that you download ASP.NET Core Runtime Hosting Bundle.
September 2, 2024 at 3:01 pm #15276Jose_1
ParticipantThanks, I reinstalled Hosting Bundle and now I can see ASP.NET Core Runtime on my module.
September 4, 2024 at 7:27 am #15287danna
I am currently having an issue on installing the scada as the scada web is not found. I am not able to logged in as well on the forum.
Are you able to help me with this?September 4, 2024 at 11:28 am #15296
Please make similar screenshots of your system as you can found in this topic.March 14, 2025 at 1:09 pm #16243Sparkle75
ParticipantI created a view with a table, but the table does not display any information to the web page. I keep going through the steps in the YouTube video, but nothing. Also, there is no Interface item on the tree.
March 17, 2025 at 10:28 am #16248
Screenshots of the settings and results would help to solve the issue.March 17, 2025 at 11:21 am #16249Sparkle75
ParticipantIncorrect format of data received from the server: data length is too big
2025-03-14 14:38:22 [QA-TIM-R][QA-TIM-R$][ACT] Receive the configuration database
2025-03-14 14:38:22 [QA-TIM-R][QA-TIM-R$][ERR] Error checking server connection:
2025-03-14 14:38:32 [QA-TIM-R][QA-TIM-R$][ACT] Receive the configuration database
2025-03-14 14:38:32 [QA-TIM-R][QA-TIM-R$][ERR] Error checking server connection:
2025-03-14 14:38:42 [QA-TIM-R][QA-TIM-R$][ACT] Receive the configuration database
2025-03-14 14:38:42 [QA-TIM-R][QA-TIM-R$][ERR] Error checking server connection:
2025-03-14 14:38:52 [QA-TIM-R][QA-TIM-R$][ACT] Receive the configuration database
2025-03-14 14:38:52 [QA-TIM-R][QA-TIM-R$][ERR] Error checking server connection:
2025-03-14 14:39:02 [QA-TIM-R][QA-TIM-R$][ACT] Receive the configuration database
2025-03-14 14:39:02 [QA-TIM-R][QA-TIM-R$][ERR] Error checking server connection:
2025-03-14 14:39:12 [QA-TIM-R][QA-TIM-R$][ACT] Receive the configuration database
2025-03-14 14:39:12 [QA-TIM-R][QA-TIM-R$][ERR] Error checking server connection:
2025-03-14 14:39:21 [QA-TIM-R][QA-TIM-R$][ACT] Webstation is stoppedMarch 17, 2025 at 12:16 pm #16250Sparkle75
ParticipantAnd under “Instance Status” it has that the Server and Communicator are Normal, but the Webstation is “Status not supported”.
Not having any success getting the screenshots. Sorry!
BTW, using Windows 10 ProMarch 17, 2025 at 1:00 pm #16251Sparkle75
ParticipantWould you be able to explain the process of how the data from the Communication lines is transferred to the WebStation? I think understanding the process would greatly help in troubleshooting.
Thanks!
Tim -
