Forum Home › Forums › Installation Issues › SCADA-Web Installation › Mimic(мнемосхема)
- This topic has 37 replies, 2 voices, and was last updated 10 years, 8 months ago by
Evgen.
November 5, 2015 at 2:12 pm #660
Evgen
ParticipantHello!
I am interested in the ability to mimic the output through the Rapid SCADA. As they draw and how to display data from the controller to mimic?
Thank you in advance!November 5, 2015 at 7:29 pm #661
As I understand, you’d like to emulate incoming data? There are 2 way to do it:
1. Send values from Generator page of SCADA-Server.
2. Install Matrikon OPC Simulation Server and establish a connection with it.If you mean something else, please let me know.
November 6, 2015 at 6:35 am #667Evgen
ParticipantI connected the controller KODESIS IF amplifier and output the data in the table.
As in this figure
https://yadi.sk/i/0BLIJ0gIkGGtH
And I need a beautiful picture.
Here are some here.
https://yadi.sk/i/nZfjXhxbkGH7N
How to do it?PS I write in Russian and use a translator program on this, you can not understand me.
November 6, 2015 at 6:38 am #668Evgen
ParticipantKODESIS IF this incorrect translation, the original of a CodeSys OPC
November 6, 2015 at 8:01 am #671
MikhailModeratorFirst of all, with help of SCADA-Administrator and SCADA-Communicator configure data obtaining from OPC server: http://rapidscada.org/connecting-devices-using-opc-standard/
Then open SCADA-Scheme Editor and create a beautiful scheme. Bind controls to the input channels that were created in the first step. Open SCADA-Web Configurator application and add your scheme.
Follow up questions are welcome.
November 6, 2015 at 8:25 am #672Evgen
ParticipantI have set up data acquisition with opc server !!!!
here’s how to draw diagrams in the editor? I have only to insert the inscription there !!! No lines or shapes.
and there vozmozkost paste the finished drawing to add controls?November 6, 2015 at 2:37 pm #673
MikhailModeratorCreate a background image with any graphical editor you prefer. Then open SCADA-Scheme Editor, add the background and add dynamic elements.
November 9, 2015 at 6:55 am #678Evgen
ParticipantMichael thanks for the tips.
I now have a question, and there are other interfaces RapidSKADA. Manager wants different options to choose from. or if there is a way to change the interface.November 9, 2015 at 7:35 am #680
MikhailModeratorPlease provide more information about interfaces that you need. Do you mean styles or something else?
November 9, 2015 at 8:03 am #681
MikhailModeratorYou can call me and ask common questions.
November 9, 2015 at 9:13 am #682Evgen
ParticipantYes you are right I’m interested in styles.
November 9, 2015 at 9:18 am #683Evgen
ParticipantUnfortunately, I can not call you at work since.
November 9, 2015 at 9:27 am #684Evgen
ParticipantI must place on the Welcome page logo where I work page now looks like this
November 9, 2015 at 9:46 am #685
MikhailModeratorFind images here C:\SCADA\ScadaWeb\images and replace the appropriate image.
Also you may edit *.aspx files if you are able to use HTML.November 13, 2015 at 8:10 am #704Evgen
ParticipantHow you can contact? I have a question and I need a more detailed explanation.
And thanks again for all the advice you gave. Very helpful. -
