Forum Home › Forums › Communicating with Devices › Modbus › Error Communication Failed
- This topic has 33 replies, 4 voices, and was last updated 7 months, 1 week ago by
April 13, 2026 at 12:23 pm #17835
Gabor
ParticipantHi Mikhail! Thank you for your help. Ok, I will try to change device ID..once I am back to the device in the afternoon. Yes, I have already tried the modbus parser, but could only do for the request as there were no response. So there were not much to decode, but understood the structure of the packet.
April 13, 2026 at 7:06 pm #17836Gabor
ParticipantHello, sorry but it didn’t work.. I tried all the possible device IDs (i can think of), but couldn’t make the connection. Investigated with Wireshark, and noticed after the Modbus/TCP query there is the TCP response from the unit, but with the following:
Conversation Completeness: Incomplete, DATA(15)
RST: Absent
FIN: Absent
..the rest is Present. So now I am not sure whether it is still depending on the wrong device ID, or something else (firewall,lost packets,etc.)April 13, 2026 at 8:30 pm #17837
manjey73Participantcopy the contents of the response from wireshark to modbus parser from the data block and find out. if there is an adequate response, then configure the firewall.
April 13, 2026 at 8:56 pm #17838Gabor
ParticipantFrame 170750: Packet, 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface \Device\NPF_{F2678167-79C5-471E-B087-1B9E7024FEE4}, id 0
Section number: 1
Interface id: 0 (\Device\NPF_{F2678167-79C5-471E-B087-1B9E7024FEE4})
Encapsulation type: Ethernet (1)
Arrival Time: Apr 13, 2026 21:41:59.747783900 GMT Daylight Time
UTC Arrival Time: Apr 13, 2026 20:41:59.747783900 UTC
Epoch Arrival Time: 1776112919.747783900
[Time shift for this packet: 0.000000000 seconds]
[Time delta from previous captured frame: 92.127100 milliseconds]
[Time delta from previous displayed frame: 92.127100 milliseconds]
[Time since reference or first frame: 2 hours, 43 minutes, 42.354718200 seconds]
Frame Number: 170750
Frame Length: 60 bytes (480 bits)
Capture Length: 60 bytes (480 bits)
[Frame is marked: False]
[Frame is ignored: False]
[Protocols in frame: eth:ethertype:ip:tcp]
Character encoding: ASCII (0)
[Coloring Rule Name: TCP]
[Coloring Rule String: tcp]
Ethernet II, Src: Espressif_80:6d:97 (b8:d6:1a:80:6d:97), Dst: Intel_19:e8:ad (e8:b1:fc:19:e8:ad)
Destination: Intel_19:e8:ad (e8:b1:fc:19:e8:ad)
…. ..0. …. …. …. …. = LG bit: Globally unique address (factory default)
…. …0 …. …. …. …. = IG bit: Individual address (unicast)
Source: Espressif_80:6d:97 (b8:d6:1a:80:6d:97)
Type: IPv4 (0x0800)
[Stream index: 24]
Padding: 000000000000
Internet Protocol Version 4, Src: 192.168.1.106, Dst: 192.168.1.100
0100 …. = Version: 4
…. 0101 = Header Length: 20 bytes (5)
Differentiated Services Field: 0x00 (DSCP: CS0, ECN: Not-ECT)
Total Length: 40
Identification: 0x02c1 (705)
000. …. = Flags: 0x0
…0 0000 0000 0000 = Fragment Offset: 0
Time to Live: 255
Protocol: TCP (6)
Header Checksum: 0x34f0 [validation disabled]
[Header checksum status: Unverified]
Source Address: 192.168.1.106
Destination Address: 192.168.1.100
[Stream index: 59]
Transmission Control Protocol, Src Port: 502, Dst Port: 50060, Seq: 1, Ack: 2617, Len: 0
Source Port: 502
Destination Port: 50060
[Stream index: 287]
[Stream Packet Number: 440]
[Conversation completeness: Incomplete, DATA (15)]
..0. …. = RST: Absent
…0 …. = FIN: Absent
…. 1… = Data: Present
…. .1.. = ACK: Present
…. ..1. = SYN-ACK: Present
…. …1 = SYN: Present
[Completeness Flags: ··DASS]
[TCP Segment Len: 0]
Sequence Number: 1 (relative sequence number)
Sequence Number (raw): 3560975033
[Next Sequence Number: 1 (relative sequence number)]
Acknowledgment Number: 2617 (relative ack number)
Acknowledgment number (raw): 2177597505
0101 …. = Header Length: 20 bytes (5)
Flags: 0x010 (ACK)
000. …. …. = Reserved: Not set
…0 …. …. = Accurate ECN: Not set
…. 0… …. = Congestion Window Reduced: Not set
…. .0.. …. = ECN-Echo: Not set
…. ..0. …. = Urgent: Not set
…. …1 …. = Acknowledgment: Set
…. …. 0… = Push: Not set
…. …. .0.. = Reset: Not set
…. …. ..0. = Syn: Not set
…. …. …0 = Fin: Not set
[TCP Flags: ·······A····]
Window: 3128
[Calculated window size: 3128]
[Window size scaling factor: -2 (no window scaling used)]
Checksum: 0x58f4 [unverified]
[Checksum Status: Unverified]
Urgent Pointer: 0
[Timestamps]
[Time since first frame in this TCP stream: 4 minutes, 29.500762100 seconds]
[Time since previous frame in this TCP stream: 92.127100 milliseconds]
[SEQ/ACK analysis]
[This is an ACK to the segment in frame: 170749]
[The RTT to ACK the segment was: 92.127100 milliseconds]
[iRTT: 6.205400 milliseconds]
[Client Contiguous Streams: 1]
[Server Contiguous Streams: 1]
This was the repsonse. Not sure what to input to the parser..April 14, 2026 at 3:11 am #17839
manjey73ParticipantDestination Port: 50060Why would that be?
April 14, 2026 at 4:07 am #17840Gabor
ParticipantNow I checked it,and originally it is sending that Modbus request from that port. How can I change that to 502?
April 14, 2026 at 6:51 am #17841
manjey73ParticipantI can’t tell you who is changing the port, but the server, when sending to port 502, expects it to return to port 502.
April 14, 2026 at 8:49 am #17842Gabor
ParticipantSorry i think there is a confusion: it is a home setup,where ip100 is requesting communication and data from ip106 (target modbus device).So the modbus device responds correctly from port 502 to port 50060,because initially the request was from port 50060 to port 502. I just assumed rapid scada already setup the port 502 for modbus communication, and can’t understand where this 50060 is coming from.. So as far I understand both unit should use port502..?
April 14, 2026 at 11:29 am #17843
manjey73Participantshow the text of the device log starting from the start of the line
April 14, 2026 at 12:51 pm #17844
JurasskParkParticipantPeriod = 00:00:00
https://postimg.cc/rdhCSyfPApril 14, 2026 at 12:57 pm #17846
MikhailModeratorLikely port 502 is required.
April 14, 2026 at 12:59 pm #17847Gabor
ParticipantThank you for the responses! Yes, will check why it is not using port 502,maybe some other application took that port.
Manjey: will send it soon..
Jurassk: it can be zero according to documentation:
Time and Period If both options are zero, the device is polled continuously and cyclically. If the time is specified and the period is zero, the device is polled once a day at the specified time. If the period is greater than zero, the device is polled periodically, starting at the specified time.April 14, 2026 at 3:18 pm #17848Gabor
ParticipantManjey: Do you mean this log after restarting the line?
https://postimg.cc/xckShQMrThe connection is already established with the wrong port:
https://postimg.cc/Mnxjt9fGHowever, I cannot connect to the port 502 on localhost, using telnet.
Connecting To 192.168.1.100…Could not open connection to the host, on port 502: Connect failed
C:\WINDOWS\system32>telnet 127.0.0.1 502
Connecting To 127.0.0.1…Could not open connection to the host, on port 502: Connect failedif anyone has an idea how to free up this port..?
April 15, 2026 at 3:21 am #17850
manjey73Participantcheck the open ports in the system. the
netstatcommand, if I’m not mistaken.April 15, 2026 at 4:18 am #17851Gabor
ParticipantI used a Port Scanner: server has port 80 and 502 open. My laptop/client does not have 502 port open, but it seems it is not needed, found this site which explains it nicely:
https://scadaprotocols.com/modbus-tcp-ip-port-502-iana
So its normal to use ephemeral port to connect.
Will do some more troubleshooting with wireshark, because it looks like the 3way handshake is done,but no data is communicated. -
