Viewing 15 posts - 751 through 765 (of 6,287 total)
  • in reply to: Sending MQTT commands #15690
    Likely, the channel properties are incorrect. Make sure that the tag code of the channel is set.
    in reply to: Sending MQTT commands #15678
    Please send screenshots:
    1. A screenshot of the correct command when you send it from the Administrator app.
    2. Screenshot of a command when you send it with a button.
    in reply to: Modbus Data error #15677
    Use the Modbus parser to validate your requests.
    in reply to: Sending MQTT commands #15672
    1. I recommend to use short Tag codes for your convenience.
    2. When you send a command, specify the tag code in the Command code field.
    Command value is data to send, just a number.
    in reply to: Modbus Data error #15671
    Note that ILLEGAL DATA ADDRESS is the answer of your device.
    in reply to: Modbus Data error #15670
    If you have communication logs from the previous version, compare the Modbus packets with the new version using https://rapidscada.net/modbus/
    in reply to: Connection state is Error #15658
    You right, it will be useful.
    in reply to: Sending MQTT commands #15657
    Please provide screenshots of the settings, and commands sent.
    in reply to: Connection state is Error #15653
    May be some other application affected network communications. Windows update also may be the cause.
    I would prefer Linux for server software that needs to run 24/7.
    in reply to: Sending MQTT commands #15652
    You don’t need to add commands in the device properties. You can just write data to elements of subscriptions.
    in reply to: Sending MQTT commands #15651
    In the Administrator app, right-click the device, choose Send command. Type the tag code as a command code and send. Does it work? If not, check a communication line log.
    in reply to: DrvDbImportPlus #15647
    in reply to: Modbus Simulator Issues #15646
    Dear Bryan,
    Please copy in this topic a part of a communication line log that contains error details.
    in reply to: Sending custom data from SCADA Admin app to Server #15641
    If a path should be entered in the Administrator application, it can be done via module user interface. Like Auto Control Module does, for example. Module configuration is stored in an XML file as a part of the project.
    in reply to: ExtraSchemeComponentsPlugin Registration bug #15637
    I suppose, the plugin will generate the computer code when you upload the project, containing a scheme (mimic diagram) containing that components. And activate the plugin, of course.
