Viewing 15 posts - 6,016 through 6,030 (of 6,279 total)
  • in reply to: opc on network #754
    SCADA-Web connects to SCADA-Server using TCP port 10000. Check the connection settings with SCADA-Web Configurator utility.
    Port 80 is used by IIS. I should not use it for other purposes.
    in reply to: opc on network #746
    Browse OPC Server via UI of SCADA-Communicator doesn’t depends on connection with SCADA-Server. What error message appears?
    You have to allow incoming TCP connection through 10000 port on a firewall on a PC where SCADA-Server installed.
    in reply to: unable to load view on web #744
    Any information about your project is welcome πŸ™‚
    in reply to: unable to load view on web #742
    Hi Ali,
    What OS do you use?
    in reply to: disable MΓ‘ximum failed session count en 4.5 #737
    Good news πŸ™‚
    Thank you for your help in finding the cause.
    I’ll include the fix in the distributive within a few days.
    in reply to: disable MΓ‘ximum failed session count en 4.5 #734
    You have found a major bug. Thanks!
    I’ve sent you a fix. Please try it and post a result here.
    Do not forget to return Device request retries count on error back to 3.
    in reply to: Mimic(мнСмосхСма) #732
    1. The additional component ChartList
    scada chartlist
    2. Component for Charting
    These components are commercial. I will send you an offer by e-mail.
    in reply to: Mimic(мнСмосхСма) #726
    This is the frequent question. In the current version 4.5 you can display a gauges and meters using a set of images. Each image for the each value. Otherwise use text labels. In the spring of 2016 we are going to create a new SCADA-Web with required graphical components.
    in reply to: scada server error #722
    I agree that the manual is not rich of examples. In case of restricted resources the best way is to simplify the UI to allow a user easily understand how to configure a system.
    This forum is a knowledge base. Be free to ask for examples (in a new topic).
    in reply to: scada server error #720
    Google Translate translates German completely unclear )
    in reply to: scada server error #719
    Thanks for the improvements of the instruction )
    I use WinSCP for copying files from my Windows workstation. And Putty with MidnightCommander (mc) to run scripts.
    Have you solved the issue caused by decimal separator?
    in reply to: check the status of one or more bits in 2 bytes #716
    You can import C:\SCADA\BaseDAT\formula.dat from the distributive v4.5 using SCADA-Administaror. It contains GetBit function.
    in reply to: check the status of one or more bits in 2 bytes #715
    Hi!
    GetBit appears since Rapid SCADA v.4.5
    I think you have tried to use this formula in v.4.4
    in reply to: Mimic(мнСмосхСма) #710
    Hi!
    If you use the same monitor, check scaling in your browser.
    in reply to: Mimic(мнСмосхСма) #708
    It seems you can not do without creating a new configuration similar to the existing.
