MikhailModerator
MikhailModeratorEmail support is available as a part of commercial Extended support http://rapidscada.org/services/technical-support/
In case of free support, use any other image hosting, ftp, file sharing service, etc.
MikhailModeratorPlease provide screenshots of your settings.
MikhailModerator
MikhailModeratorI need screenshots of the web page and the Interface table of Administrator app, you can use any image hosting to publish screenshots that you prefer.
You can make a fork of https://github.com/RapidScada/scada and edit js, css, etc. as you need.
MikhailModeratorOpen WebSettings.xml of the new Webstation and check CommSettings section.
I recommend to test migration on clear virtual machine.
MikhailModeratorDoes the old version of the web application work well or not?
Is the connection between Sever and Communicator established?
MikhailModeratorDid you get installation errors during the installation process?
Can you run SCADA-Server shell or not?
What Windows version do you use?
Please provide log or screenshots.
MikhailModeratorPlease create A NEW TOPIC:
1. Go to this subforum
2. Scroll the page down and find a text Create New Topic in “Installation Issues”
3. Describe your issue in details, including links to screenshots.
4. Press Submit button.
MikhailModeratorColumns just change their display names, but were not changed in the database ))
MikhailModeratorSorry, my advice was not fully correct.
You can manually install Webstation into C:\SCADA\ScadaWeb5 and give a name Scada5 for the website.
Use this manual in the part describes web app installation.March 3, 2017 at 12:43 pm in reply to: Comunication with Siemens Plcs via Profinet or Ethernet #1980March 3, 2017 at 5:54 am in reply to: How to get the data which automatically sent by the devices? #1978
MikhailModeratorPlease create a new topic and provide more details.
