MikhailModeratorPlease provide a screenshot of your Windows features dialog. I suppose, WCF was not installed.
MikhailModeratorCool!
MikhailModeratorY axis is scaled automatically depending on the range of values.
Do you want fixed scaling by Y?
MikhailModeratorIt’s better to restore the default values:
SCADA-Server uses port 10000.
IIS web server (the web application) uses port 80.I suggest to help you by remote connection for a fee. It will save your time.
This is something new.
Please send me the content of C:\SCADA\ScadaComm\Config to reproduce the bug.
Also describe the sequence to raise this error.-
This reply was modified 8 years, 7 months ago by
You right to avoid writing email here.
Please send your vision to email published here.
MikhailModeratorDon’t use port 10000 for web application. It works on port 80 by default.
What is shown by http://localhost/scada/Login.aspx ?
Features seem OK.
Try http://localhost/ Does it work?
Please check, may be the default port 80 is used by another web server?
MikhailModeratorIf you set en-US or pt-BR, for example, formatting will be changed but the software loads the existing en-GB files.
1. Create a set of images with different levels by your favorite graphical editor.
2. Use Dynamic Picture component and define Conditions property to change image according to the current value.Note: a control library includes ready to use level control is under development currently.
MikhailModeratorThank you for the detailed explanation.
I think the appropriate plugin should be implemented as a custom development. We could discuss the requirements and a price by email.Your English is good enough 🙂
MikhailModeratorHi Joao,
You right. This is a known issue. I want to add an option to remove legend.
Formatting depend’s on the culture that is set in Webstation settings and this culture parameters of the server. For example, en-GB.
MikhailModeratorI typed this into Google and got huge amount of different diagrams. Could you provide an example with energies?
MikhailModeratorOK 🙂
