Viewing 15 posts - 5,206 through 5,220 (of 6,285 total)
  • in reply to: Function to Send Command #2767
    This link requires authorization. Can you share it for all?
    in reply to: Webpage Error Localhost and Remote #2766
    Press F12 in the browser, quickly open the Console tab and make a screenshot.
    in reply to: Function to Send Command #2761
    First of all, you should create a Modbus template in the Communicator application.
    If you already create the template, please provide a screenshot. Otherwise, create a template and try to send a command using the UI of Communicator.
    in reply to: Webpage Error Localhost and Remote #2759
    Disable activations subitems of .Net 3.5.1 node. This is important.
    in reply to: Username and password #2758
    Did you change a password of ScadaComm user in the Administrator app or change user and password in Common parameters of Communicator?
    in reply to: Telegram bug #2747
    Thanks a lot!
    I’ll try the next week and let you know.
    in reply to: Understanding Inputs Outputs and formulas #2746
    πŸ™‚
    in reply to: Webpage Error Localhost and Remote #2745
    The screenshot is not accessible.
    in reply to: Dashboard Chart #2740
    OK πŸ™‚
    in reply to: Telegram bug #2739
    Do you still want me to send you any data?
    I also tried to reproduce the bug. But I can’t. I’m sure the bug exists, but we need to know the magic sequence how to raise it. If you realize this sequence, tell me, please. You don’t need to send me the config now.
    in reply to: Chart Pro Y Axis scaling #2736
    I sent an email.
    in reply to: Dashboard Chart #2735
    Thank you for the link. It’s better than a screenshot.
    Try http://fischerp.selfhost.eu:8888/Scada/View.aspx?viewID=2
    You will get “The requested view does not exist or you have insufficient rights to access it.”
    You specified
    Widget type=”Chart” cnlNums=”601,602,603,604,605β€³ viewIDs=”2,2,2,2,2β€³
    in the dashboard settings.
    But you have to specify the existing view that really contains the channels 601…605
    May be viewIDs=”64,64,64,64,64β€³
    in reply to: Understanding Inputs Outputs and formulas #2734
    Of course.
    What a formula do you plan to use in mathematical manner?
    in reply to: Dashboard Chart #2730
    Hi Peter,
    I don’t think that the error relates to a new key. Anyway we need to solve it.
    View is a scheme or a table which is specified in the Interface table in Administrator.
    What is the URL of the page with the error?
    Copy here the errors from the logs of SCADA-Server and Webstation.
    Post here a link to a screenshot of the Interface table.
    Post here the dashboard configuration, please.
    in reply to: Chart Pro Y Axis scaling #2729
    This feature requires modification of the plugin source code. We could discuss the custom development by email.
