July 31, 2025 at 10:51 am in reply to: Error “was not in a correct format” when parsing telemetry time #16757
To be able to receive a timestamp, try converting the incoming data to a double encoded as OLE Automation date
Thank you for the update.
Probably, the channel type should be changed to Input.
The channel does not refer to another source channel. It receives values from Communicator.
I recommend to upgrade Rapid SCADA and the module to the latest versions. When you download the distributive from our website at one time, the application and module versions are compatible.
Please provide a screenshot of the error. Make sure that all prerequisites are installed.
You are welcome. Please send the amount by email as the payment link must contain a fixed amount.
MikhailModeratorTo clarify: you mean to define 2 device pollings, first for data and second for this log events. Second one should poll only for command?
That’s right.
MikhailModeratorYou could try Grafana with Rapid SCADA in case of specific needs.
In fixed mode, the period is specified in days. So the minimum chart interval is from 0 to 24 hours.
I have created a support ticket with the manufacturer and await their response.
I suppose, the manufacturer should somehow comment the situation. Please notify us about the result.
MikhailModeratorOK 🙂
July 24, 2025 at 9:46 am in reply to: Under what circumstances will all channel data be cleared? #16711
Channel data is cleared if no new data comes, or when it’s set to an empty data.
MikhailModeratora value greater than 0, such as 5, and then I have to read addresses 0x1000 to 0x1005 to get 5 events
You can send a command to poll the device using Automatic Control Module. Then try to generate events with the same module. Before developing a new driver, it’s worth trying.
From such a driver, would I be able to read any ModBus device registers and generate SCADA events based on them?
Yes.
is there a minimal example of a ModBus device driver available that I could follow?
Check the existing drivers, especially DrvModbus, DrvEnronModbus and DrvSimulator.
This reply was modified 10 months, 3 weeks ago by
According to Modbus Parser, the following data is requested:
https://ibb.co/bjB7xMyCDoes it match the Modbus register map?
Probably, you can read the most recent event from the fixed Modbus address. Then you will get it as channel values. How will you process those channel values? -
