Auto Control Module Configuration Errors
Forum Home › Forums › Understanding the Software › Auto Control Module Configuration Errors
  • #16741
    CCKOH
    Hi Mikhail,
    I hope you’re having a good day.
    I’m currently running the Scada Server Version 6.2.0.0 and the Auto Control Module Version 6.1.0.1.
    I encountered two issues when trying to configure the Auto Control Module:
    1. When I click the Properties button, the following error message appears: **”Error loading module configuration: Root element is missing.”**
    2. After completing the configuration and clicking the Save button, I receive another error message: **”Error saving module configuration: Method not found: ‘System.Xml.XmlElementScada.ScadaUtils.AppendElem(System.Xml.XmlNode, System.String, System.Object)'”**.
    Do you have any ideas about why these errors are occurring? For your information, I have already unblocked all the .dll files associated with the Auto Control Module.
    Thank you for your assistance.
    Best regards,
    CC Koh
    #16744
    There was a similar error when switching from version 6.3.X to 6.4.x, or even when switching to 6.3.X, some methods changed there. And it’s possible that your module version doesn’t match the kernel version.
    Check the version history in the documentation
    #16745
    Rapid SCADA 6.2.0 (27.01.2024)
    Server 6.2.0.0
    Apparently, your Scada version is still 6.2.0
    #16746
    It seems to be easy to switch between these versions by simply copying files without affecting the Config folder (I do this). And updating all modules and other relevant ones.
    I recommend 6.4.1 – now there is no need to create your own windows to display the PC code, and you can use a regular window with your own PC code file and your own links in the registration window šŸ™‚
    #16748
    I recommend to upgrade Rapid SCADA and the module to the latest versions. When you download the distributive from our website at one time, the application and module versions are compatible.
    #16750
    CCKOH
    Hi Mikhail and Manjey,
    Thank you for the recommendation. I have updated to the latest version of Rapid SCADA, and the Auto Control Module is functioning now.
    Regards,
    CCKOH
    #16759
    šŸ™‚
