Viewing 15 posts - 3,946 through 3,960 (of 6,299 total)
  • in reply to: Error updating the hourly data #6193
    For some reason the hourly data contains wrong symbol. Please switch to the Network tab in Chrome, find the appropriate response and copy here.
    in reply to: Retain Variable #6191
    For the question that is not related to the current topic, please create a new topic.
    in reply to: Retain Variable #6189
    For the both questions:
    You could create a new formula in the Formulas table. Something like that:
    double UpdateTime(double val, int timeCnlNum)
      SetVal(timeCnlNum, EncodeDate(DateTime.Now));
      return val;
    and use it for example
    Stat > 0 ? UpdateTime(Cnl * 100 + 1, 1001) : Val()
    The formulas are not tested.
    in reply to: Installation problem #6186
    May be you can install Midnight Commander, run it from command line like
    sudo mc
    and copy the files.
    I usually connect to Linux machines remotely by SSH without desktop.
    in reply to: Installation of Webstation plugins #6184
    Cool )
    in reply to: Cannot start services on Ubuntu 16 #6179
    Good 🙂
    in reply to: Installation of Webstation plugins #6177
    Tick the Unblock checkbox, then click OK.
    in reply to: Cannot start services on Ubuntu 16 #6172
    You started SCADA-Server from command line, but it should be started automatically as a daemon. Probably some installation steps failed and daemons are not registered properly.
    There are 3 daemons: Server, Communicator and Agent. You can find them in the appropriate folders. All of them should be started.
    The daemons write log files located in “Log” subfolders. You should check these files.
    in reply to: Installation problem #6169
    How do you copy files?
    in reply to: Use of the buttons #6168
    Can it be a problem with my configuration?
    To answer this questions I need more info what was expected and what is actual.
    in reply to: Cannot start services on Ubuntu 16 #6167
    Set the server folder as a current and run
    mono ScadaServerMono.exe
    What is the result?
    in reply to: Installation of Webstation plugins #6166
    Please do the following:
    1. Open the file properties of PlgSchExtraComp.dll in Windows explorer.
    2. Open the General tab.
    3. Make a screenshot of it.
    in reply to: Installation of Webstation plugins #6162
    Try unblocking PlgSchExtraComp.dll
    in reply to: Installation of Webstation plugins #6156
    Please check C:\SCADA\ScadaSchemeEditor\Log\ScadaSchemeEditor.log for additional information. When the editor starts, it loads all the components. In case of any error, it writes to the log file.
    in reply to: Use of the buttons #6154
    It was the idea. I can connect to your PC and debug the formulas for a fee.
