Viewing 15 posts - 226 through 240 (of 6,282 total)
  • in reply to: SMS with two factor authentification #17380
    As a recap:
    – You can send notifications with custom text using the phone book,
    – You need to configure commands sent by ACM
    in reply to: SMS with two factor authentification #17379
    Let’s discuss ACM triggers in a new topic. I suppose, it’s possible to find the appropriate type of trigger.
    I suggest to enable a detailed log in the data source properties. It allows to check published data.
    Log files can be found in Communicator – Logs.
    Screenshots are needed to help you.
    in reply to: SMS with two factor authentification #17372
    To use a phone book, see the available commands in the driver description on the Drivers page.
    in reply to: SMS with two factor authentification #17370
    Example of the content:
        "from": "SCADA",
        "to": [phone],
        "message": "[text]"
    Set ParamEnabled to true.
    in reply to: SMS with two factor authentification #17369
    You wrote
    -Body '{"phoneNumber":"+48111111111","message":"Test API"}'
    It’s related to the request contents, not headers.
    in reply to: SMS with two factor authentification #17368
    I’ve checked the source code of the driver.
    Parameters (phone number and text) can be inserted in the request URL and content.
    This is so weird that the service requires to insert phone number in the request header. Usually headers contain auth tokens and similar things.
    P.S. Phone number in the above was changed.
    • This reply was modified 6 months, 1 week ago by Mikhail.
    in reply to: SMS with two factor authentification #17360
    Is it possible for you to select an alternative service that needs only one HTTP request to send a message?
    in reply to: SMS with two factor authentification #17359
    Probably, the existing driver does not preserve a token returned by the 1st request.
    in reply to: SMS with two factor authentification #17358
    Check DrvHttpNotif driver. It can send HTTP requests according to commands.
    To send a sequence of commands, use Auto Control Module.
    Ask for additional info if needed.
    in reply to: Virtual Machine integration #17355
    Note that the Agent service uses user/password from its configuration file.
    Try changing the password to the default scada
    If it works, set any password you need, update it in the Agent’s configuration, and restart Agent.
    in reply to: Regarding Map Plugin Data Integration from SQL Database #17347
    I suggest to download and try.
    in reply to: In terms of usage #17345
    Would this be considered a derivative product?
    I think, yes.
    in reply to: Regarding Map Plugin Data Integration from SQL Database #17344
    To fetch data from the DB use Database Import Driver.
    Then display those data on by the Map plugin.
    The web application of Rapid SCADA uses its own web API.
    in reply to: In terms of usage #17341
    The AI answer:
    Apache License 2.0 – Simple Explanation
    Apache 2.0 is a very friendly and popular open source license with one main rule and several important requirements.
    Imagine you’re taking someone’s open source code (Project A) under this license to create your own project (Project B).
    ✅ What You CAN Do (Almost Everything):
    • Use freely: Copy, modify, distribute, and use the code commercially – for free. You can even sell products containing it.
    • Create derivatives: Mix this code with your proprietary code without opening your entire project’s source.
    • Patent rights: Original authors grant explicit permission to use related patents. If you sue someone over patent infringement related to this code, your rights automatically terminate.
    📋 What You MUST Do (Important Requirements):
    When distributing your program (Project B) containing Apache 2.0 code:
    • Keep notices: Don’t remove original copyrights, patent notices, and Apache 2.0 license text from source files.
    • Include LICENSE file: Include a copy of Apache 2.0 license when distributing your project.
    • Show changes: Clearly mark any modifications to original files (usually with code comments).
    • Notify users: Clearly indicate which parts of your project are under Apache 2.0 (typically in a NOTICE file).
    🎯 In Simple Terms:
    “You can take this code and do almost anything with it, even in commercial projects. But you must keep the original copyrights visible and honestly acknowledge you used someone else’s work under Apache 2.0.”
    ⚖️ Key Differences From Other Licenses:
    • Similar to MIT: As permissive as MIT but adds explicit patent terms and formal change documentation requirements.
    • Different from GPL: NOT “copyleft” or “viral” – you don’t have to open-source your entire project. You can keep proprietary code closed.
    📝 The Bottom Line:
    Apache License 2.0 works for both business and community. It protects authors through attribution and protects users with explicit patent rights, while allowing free use in commercial products.
