Probably, another solution is needed in that case. Please provide screenshots of your settings for better understanding.
MikhailModeratorWhile in the USA the comma is used as the 1000 separator, in Europe it is the period.
Please create a new topic. Some simple actions may be needed.
MikhailModeratorLikely, the channel properties are incorrect. Make sure that the tag code of the channel is set.
MikhailModeratorPlease send screenshots:
1. A screenshot of the correct command when you send it from the Administrator app.
2. Screenshot of a command when you send it with a button.
MikhailModeratorUse the Modbus parser to validate your requests.
MikhailModerator1. I recommend to use short Tag codes for your convenience.
2. When you send a command, specify the tag code in the Command code field.
Command value is data to send, just a number.
MikhailModeratorNote that ILLEGAL DATA ADDRESS is the answer of your device.
If you have communication logs from the previous version, compare the Modbus packets with the new version using https://rapidscada.net/modbus/
You right, it will be useful.
MikhailModeratorPlease provide screenshots of the settings, and commands sent.
May be some other application affected network communications. Windows update also may be the cause.
I would prefer Linux for server software that needs to run 24/7.
MikhailModeratorYou don’t need to add commands in the device properties. You can just write data to elements of subscriptions.
In the Administrator app, right-click the device, choose Send command. Type the tag code as a command code and send. Does it work? If not, check a communication line log.
MikhailModeratorLink in the store is https://rapidscada.net/store/Module/en/KpDbImportPlus
MikhailModeratorDear Bryan,
Please copy in this topic a part of a communication line log that contains error details.
