Viewing 15 posts - 6,046 through 6,060 (of 6,284 total)
  • in reply to: Mimic(мнемосхема) #685
    Find images here C:\SCADA\ScadaWeb\images and replace the appropriate image.
    Also you may edit *.aspx files if you are able to use HTML.
    in reply to: Mimic(мнемосхема) #681
    You can call me and ask common questions.
    in reply to: Mimic(мнемосхема) #680
    Please provide more information about interfaces that you need. Do you mean styles or something else?
    in reply to: check the status of one or more bits in 2 bytes #679
    Does GetBit function work? If not, what are the symptoms?
    in reply to: check the status of one or more bits in 2 bytes #676
    Sorry, I didn’t catch what the problem is? Could you give an additional example, please?
    in reply to: Mimic(мнемосхема) #673
    Create a background image with any graphical editor you prefer. Then open SCADA-Scheme Editor, add the background and add dynamic elements.
    in reply to: Mimic(мнемосхема) #671
    First of all, with help of SCADA-Administrator and SCADA-Communicator configure data obtaining from OPC server: http://rapidscada.org/connecting-devices-using-opc-standard/
    Then open SCADA-Scheme Editor and create a beautiful scheme. Bind controls to the input channels that were created in the first step. Open SCADA-Web Configurator application and add your scheme.
    Follow up questions are welcome.
    in reply to: disable Máximum failed session count en 4.5 #670
    Please post here a part of communication line log. I recommend to leave Device request retries count on error unmodified and equal to 3.
    in reply to: check the status of one or more bits in 2 bytes #669
    You need a one input channel of type Real for the value received from a device. Then you should create a separate input channel of type Calculated discrete for the each value. Use such formula for those channels:
    GetBit(Val(1),2)
    where 1 – the Real channel number, 2 – bit index
    in reply to: Mimic(мнемосхема) #661
    As I understand, you’d like to emulate incoming data? There are 2 way to do it:
    1. Send values from Generator page of SCADA-Server.
    2. Install Matrikon OPC Simulation Server and establish a connection with it.
    If you mean something else, please let me know.
    in reply to: opc on network #658
    Just set server IP address or host name in Common Parameters tab in SCADA-Communicator. They communicate via TCP.
    in reply to: opc on network #656
    You can install SCADA-Communicator on the PC where OPC server is installed.
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #655
    1. Yes.
    2. It is planned in the spring of 2016. In case of your project due dates, a release of the new version can be accelerated on a commercial base.
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #652
    As a restriction: scheme views do not work for now, table views and charts are OK. This issue will be taken into account in the future version of SCADA-Web.
    Classic OPC of cource does not work on Raspbian bacause it is based on DCOM.
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #645
    Most likely SCADA-Server and SCADA-Communicator can be installed on Windows 10 IoT on Raspberry, but I have no information about such experience. I think that SCADA-Web requires some modifications to work on Win 10 IoT. If you decide to try it, I’ll help you.
    At the moment Rapid SCADA is tested on Raspbian.
