Viewing 15 posts - 6,016 through 6,030 (of 6,284 total)
  • in reply to: Raspberry Pi & Windows 10 IoT #768
    Thanks for the idea. Next time I’ll try another power supply.
    in reply to: opc on network #763
    Did you tried opening port 10000 on a firewall?
    Port 80 is busy that is why you cant use it for SCADA-Server.
    in reply to: Mimic(мнемосхема) #760
    Could you send me by email a file of your scheme to test?
    in reply to: Mimic(мнемосхема) #758
    Please provide more details of your issue.
    in reply to: Mimic(мнемосхема) #755
    You can set bounds for an input channel using SCADA-Administrator. When the channel value is above or below defined limits, event is generated.
    If you need events when device turned ON or OFF, you should create additional channels of the type Calculated discrete and tick Write events and Events on change checkboxes for these channels.
    in reply to: opc on network #754
    SCADA-Web connects to SCADA-Server using TCP port 10000. Check the connection settings with SCADA-Web Configurator utility.
    Port 80 is used by IIS. I should not use it for other purposes.
    in reply to: opc on network #746
    Browse OPC Server via UI of SCADA-Communicator doesn’t depends on connection with SCADA-Server. What error message appears?
    You have to allow incoming TCP connection through 10000 port on a firewall on a PC where SCADA-Server installed.
    in reply to: unable to load view on web #744
    Any information about your project is welcome 🙂
    in reply to: unable to load view on web #742
    Hi Ali,
    What OS do you use?
    in reply to: disable Máximum failed session count en 4.5 #737
    Good news 🙂
    Thank you for your help in finding the cause.
    I’ll include the fix in the distributive within a few days.
    in reply to: disable Máximum failed session count en 4.5 #734
    You have found a major bug. Thanks!
    I’ve sent you a fix. Please try it and post a result here.
    Do not forget to return Device request retries count on error back to 3.
    in reply to: Mimic(мнемосхема) #732
    1. The additional component ChartList
    scada chartlist
    2. Component for Charting
    These components are commercial. I will send you an offer by e-mail.
    in reply to: Mimic(мнемосхема) #726
    This is the frequent question. In the current version 4.5 you can display a gauges and meters using a set of images. Each image for the each value. Otherwise use text labels. In the spring of 2016 we are going to create a new SCADA-Web with required graphical components.
    in reply to: scada server error #722
    I agree that the manual is not rich of examples. In case of restricted resources the best way is to simplify the UI to allow a user easily understand how to configure a system.
    This forum is a knowledge base. Be free to ask for examples (in a new topic).
    in reply to: scada server error #720
    Google Translate translates German completely unclear )
