Viewing 15 posts - 5,236 through 5,250 (of 6,290 total)
  • in reply to: sankey #2699
    Thank you for the detailed explanation.
    I think the appropriate plugin should be implemented as a custom development. We could discuss the requirements and a price by email.
    Your English is good enough 🙂
    in reply to: Chart Pro Suggestion #2698
    Hi Joao,
    You right. This is a known issue. I want to add an option to remove legend.
    in reply to: "," of numbers #2697
    Formatting depend’s on the culture that is set in Webstation settings and this culture parameters of the server. For example, en-GB.
    in reply to: sankey #2689
    I typed this into Google and got huge amount of different diagrams. Could you provide an example with energies?
    in reply to: Modbus WAGO #2688
    OK 🙂
    in reply to: Modbus WAGO #2682
    In the new version of the Modbus driver you can switch the addressing base: 0 or 1. See Figure 10 of http://doc.rapidscada.net/content/en/use-cases/modbus-protocol.html
    in reply to: Modbus WAGO #2676
    Do you mean the address offset specified for a device or specified for SCADA?
    in reply to: How can I do?? #2672
    In this case something like that:
    Stat(101) > 0 ? GetBit(Val(101),0) : Val()
    in reply to: How can I do?? #2667
    In the formula of input channel use, for example: GetBit(Val(101),0); Stat(101)
    in reply to: Scheme Symbols/IMG #2657
    To receive notifications about new features, subscribe our Facebook page.
    in reply to: Scheme Symbols/IMG #2656
    This features will be added in the plan as soon as we can. This is a major task.
    in reply to: Scheme Symbols/IMG #2654
    Yes, you can add svg to a scheme. You should create a set of images with different level of liquid and change a picture according to a value. We are going to create ready to use controls for this purpose.
    in reply to: Modbus TCP send floats #2650
    You should create commands in Template Editor and create output channels by Administrator.
    Also, how do I create a control where I can enter the value of the new SetPoint for the output channel?
    You should define output channel number for dynamic text or picture of a scheme and choose action – Send command. If you use table views, define output channel for a row.
    • This reply was modified 8 years, 8 months ago by Mikhail.
    in reply to: Modbus TCP send floats #2647
    Currently, you should use formulas of output channels to swap bytes.
    But the new version of the driver, which supports swapping bytes for commands, is under construction now.
    If you can wait for a week, we can send you a new version. In this case, please write an email to our info@…org
    Otherwise, please translate this answer by Google Translate.
    in reply to: The problem about ModDBExport module #2645
    Could you make screenshots of the settings of the module?
    If you stop the Communicator service and manually send data from Generator of the Server shell, will you get the same errors right after restart?
