MikhailModeratorSimple example of a command in the module settings:
your_email@gmail.com;subject;text
MikhailModeratorFirst off all, make sure that emails are successfully sent by Communicator only.
Go to the Device libraries page of Communicator, find KpEmail.dll and read the format of a command that is needed. This is a binary command with a string value.
When it is done, write in this topic to continue. In case of errors, provide logs or screenshots.
In this case, you should create an additional input channel that stores the required time, and show this channel in a report.
Did you check the log of the communication line? Is there something useful?
I recommend to contact the author of the MQTT driver. His email is shared on the GitHub page.
MikhailModeratorYou right, selecting a period of writing for a channel is a useful idea.
MikhailModeratorWhy do need a scheme in a dashboard?
Could you explain your case?
You can insert a link to a scheme, but it is not tested and may occur bugs.
If you do it, please describe the experience.
OK 🙂
Does it fast enough?
Try set “Chart gap” parameter to 1 second in the web app settings.
First of all, check the size of the *.sch files.
Then I recommend to press F12 in browser, open the Console tab and watch the log when a scheme is downloading. You can find what part takes more time.
Have you already created an input channel that stores max value of a day?
MikhailModeratorI think, it better to ask the author by creating an issue on GitHub.
MikhailModeratorThe author has implemented commands. See the GitHub issue for details.
Choose the way that is more easy for you according to your experience and skills. -
