Viewing 15 posts - 3,346 through 3,360 (of 6,218 total)
  • in reply to: scheme editor bug when scrolling #7782
    Fixed. The problem appeared because the scripts in the editor were not updated. Now these files are replaced in the distributive package without changing version number. You should download it again and update files in
    C:\SCADA\ScadaSchemeEditor\Web
    C:\SCADA\ScadaWeb\plugins\SchemeEditor
    in reply to: Automatic Control Module integration #7769
    Check the command type of the trigger (standard or binary).
    To avoid infinite loop:
    1. You need to create another output channel for the 2nd command.
    2. Or check the command value in the trigger.
    in reply to: Not Receiving Data from Request – Modbus #7768
    According to the log file, you can connect to the converter, but there is no response from the device.
    Check the following:
    1. The device ID is correct (is set to 5).
    2. RS-485 wires are correct. Try swapping A and B wires.
    in reply to: scheme editor bug when scrolling #7759
    I will check it and write here.
    in reply to: Administrator Find and Replace Bug #7758
    Good. The fix will be included in the next release. Thank you.
    in reply to: Automatic Control Module integration #7757
    You need to create a command trigger in the module settings. Under this trigger create a command to send “release command”. If you provide screenshots of the settings, I can check them.
    in reply to: Formula does not stop #7753
    You have to set Signal to an empty string. Otherwise the channel gets data from a device.
    in reply to: Automatic Control Module integration #7752
    Dear Han,
    Could you let me know step by step to configure to send a release command?
    Please explain your question. What is “release command”?
    in reply to: Grafana (backend) and Rapid SCADA #7751
    Could not convert string to DateTime: 1608121200227. Path ‘range.to’, line 1, position 53.
    You right, the problem is in format conversion. 1608121200227 is a number while a date string is expected.
    Merry Christmas and Happy New Year!
    in reply to: HTTPS on Linux #7745
    We recently discussed this in Russian forum. Could you use Google Translate starting from this message? Pay attention to the link to a manual which describes how to use nginx as an endpoint. We can continue the discussion here.
    in reply to: Grafana (backend) and Rapid SCADA #7744
    Try to get full exception stack where you can see a sequence of exceptions.
    What operating conditions are causing this exception?
    in reply to: ModDBExport Authentication failed #7743
    Thanks for noticing. It’s very common issue.
    in reply to: Formula does not stop #7742
    Please right click the input channel, open properties and make a screenshot of all channel properties.
    in reply to: Destination port for web portal #7741
    You should use the Administrator app. This article may help.
    It’s recommended to use Administrator on Windows and upload the project on Linux.
    in reply to: Administrator Find and Replace Bug #7738
    Please check this update. Replace the existing app files.
