Viewing 15 posts - 2,716 through 2,730 (of 6,219 total)
  • in reply to: Run Rapid SCADA in Microsoft Azure VM #9661
    1) I suggest at least Windows 10 or Linux.
    2) You need static IP address.
    3) http://SERVER_IP/scada
    If you register your domain name, you could use address like http://rapidscada.net/scada/
    in reply to: Com Ports ? #9658
    Hi Rich,
    RS-232 is just a communication interface. The most important is how data is encoded when transmitted.
    Do you successfully write values to a text file?
    Does the above formula to retrieve data from text file work?
    in reply to: Export data to SQL #9656
    The new Rapid SCADA 5.8.4 contains fully redesigned Export to Database module. I recommend to update.
    in reply to: Export data to SQL #9652
    Module screenshots and logs appreciated.
    how does the module knows wich channels to export?
    The current version of the module exports all channels. In the next version, a user can specify the channels.
    in reply to: OPC UA Driver #9648
    This error probably means that the driver version is incompatible with Rapid SCADA version.
    Please check Communicator and Administrator versions.
    Full error message would be useful, it can be copied from C:\SCADA\ScadaAdmin\Log\ScadaAdmin.err
    in reply to: Com Ports ? #9645
    The formula would be something like:
    double ReadNum()
      try
        string s = System.IO.File.ReadAllText(@"C:\mydata.txt");
        double val;
        return double.TryParse(s, out val) ? val : -1;
      catch
        return -2;
    • This reply was modified 4 years, 5 months ago by Mikhail.
    in reply to: Com Ports ? #9644
    and writes it into a text file like ‘mydata.txt’, its simple the text file just shows a single number like 22.3
    Could I not just write a formula to read this ‘mydata.txt’ file into RapidScada and then return this number from the file
    This is not optimal, however, it’s possible if the file contains only 1 number.
    Create a formula and use it for an input channel of the Calculated real type.
    in reply to: Export data to SQL #9643
    1. No, the module is free.
    2. Specify the query in the module configuration.
    If you provide screenshots of the module settings, I can check.
    in reply to: Com Ports ? #9637
    Please check the driver development article and the existing driver as an example (link 1, link 2).
    in reply to: Start menu items not exist #9632
    Despite the successful installation, only “administrator” and “Webstation” items appears in the start menu.
    It’s correct. You can control the Server and Communicator services from the Administrator app.
    The Agent service start automatically when the PC is restarted.
    in reply to: Com Ports ? #9630
    Rapid SCADA supports COM ports. But you also need a driver (dll) for Communicator that implements recognizing the data in a particular format. It’s possible to develop such driver.
    in reply to: Graph Graphics #9629
    There should be PlgChartPro.xml file in your project. The default file contains in the installation package of the plugin. Copy it into the project if it doesn’t exist.
    This file contains required parameters.
    in reply to: Rapid Gate #9628
    You did everything right.
    A new user for Rapid Gate should be of the Application role.
    in reply to: SNMP Int32 #9621
    As I remember, yes.
    in reply to: communicate device by 4G DTU #9619
    That is the solution. The 4G DTU contains the config.
    Nice 🙂
    What solution method have you chosen?
