Could you publish a screenshot where a link component is added to a scheme, and it’s properties are displayed in the properties table?
Change the channel data type to blank (double) to get large numbers.
Then add a new channel of the Calculated type, string data type and an input formulaData(101), where 101 is the source channel number.
Send screenshots of the settings and results.
Use the existing plugins as samples. In case of particular questions, ask.
We can provide a personal online training if needed.-
This reply was modified 3 years, 2 months ago by
April 6, 2023 at 8:59 am in reply to: How can I edit the source code of the scheme editor in v6 #12383
Open Task Manager and check CPU usage of different applications.
I don’t think it’s possible, because Server is a service that has no access to desktop. Web application also has no access to a desktop. It’s only possible to start a console application from Server script.
Dynamic text displays channel value. Led also is bound to a channel and reflects its value. When a button is clicked it sends a command to Server to a particular channel. You should create a channel formula that does what you need.
Please ask questions in appropriate topics. This topic is about MQTT.
MikhailModeratorTry getting a string as 4 registers of double type (8 bytes). They should be bound to 4 channels of the String data type. Let’s see the result.
MikhailModeratorCheck the output report URL in Chrome tools (F12 button, Network tab) and set it for a link component.
What is the max. length of the string?
MikhailModeratorIn the Modbus Template Editor, select an element and set its data type.
Duplicated.
Put a link component to a scheme, and specify view ID to open.
MikhailModeratorTo generate an Excel report, try using a link component.
