Viewing 15 posts - 1,546 through 1,560 (of 6,268 total)
  • in reply to: OPC DA null values because bad quality. #13257
    every signal have default limits (0 to 100) but values are higher than limits
    In this case, you get Bad quality status?
    in reply to: OPC DA null values because bad quality. #13256
    If you need to use values with bad status as good values, I can provide the source code of the OPC DA driver, so you can change it as needed.
    in reply to: SQL string 8 caracters #13252
    In SCADA I created 2 fields showing column 1 and column 2
    Good workaround. Thank you for the idea.
    in reply to: SQL string 8 caracters #13251
    The above description is correct.
    Sorry if it is studi question but how to modifiy the driver ?
    1. Change the driver by yourself using the source code.
    2. Sponsor the update, and we would implement the required feature.
    Any source code somewhere ?
    Driver’s source
    See DrvDbImport projects. For example, DrvDsOpcUaServer supports long strings.
    in reply to: Communication Lines and speeds #13250
    If you use Modbus TCP, using multiple communication lines will increase polling performance.
    in reply to: OPC DA null values because bad quality. #13249
    Bad quality status is received only by Rapid SCADA driver or also by other OPC clients, like Matrikon OPC Explorer?
    in reply to: Communication Lines and speeds #13244
    In general, communication lines work in parallel.
    in reply to: Communication Lines and speeds #13243
    It may depend on the communication protocol. Could you provide screenshots of the Communication line settings?
    in reply to: SQL string 8 caracters #13242
    Thank you for the screenshot.
    In Rapid SCADA 6 channels of the string type may contain more then 8 characters.
    However, the DB import driver currently does not support long strings. The driver needs an update to implement the required feature.
    in reply to: scada-v6 source code debug #13238
    After build, the executable and other files should be correctly copied to the runtime location as the installer does. Services must be registered in the system. Then they can be started.
    in reply to: SQL string 8 caracters #13237
    Could you provide a screenshot?
    in reply to: add new condition ins scada scheme V5 #13234
    My be it’s better to create new components inheriting them from the existing, because in this case you have more freedom to add new features.
    in reply to: Add formula in RapidScada v6 #13233
    The instruction is here. In Rapid SCADA 6 the Formulas table was renamed to Scripts. You should copy from line 21 to 205.
    The formulas also should work on the 6th version.
    in reply to: add new condition ins scada scheme V5 #13230
    I think, it’s better to develop new components using the existing components as base classes, or as examples.
    in reply to: Require password to open ScadaAdmin #13229
    There is no password in ScadaAdmin. However, it would be useful.
    You could prevent other users to change the project it by configuring Windows access rights on the application and project folders.
