Viewing 15 posts - 5,971 through 5,985 (of 6,265 total)
  • in reply to: SCADA-Scheme Editor does not work #832
    Could you post a screenshot of http://localhost/scada/scheme/ScadaSchemeSvc.svc ?
    in reply to: SCADA-Scheme Editor does not work #830
    Does it help?
    in reply to: Sending Email Notifications #829
    I’ll help you. Just create a new topic in Installation Issues
    in reply to: SCADA-Scheme Editor does not work #827
    In Win 7 the required feature is included in .NET Framework. You don’t need to tick checkbox.
    Please check that application pool with .NET 4 is chosen for Scada web application. Use IIS Manager for this purpose.
    in reply to: SCADA-Scheme Editor does not work #825
    Please check that HTTP Activation feature for .NET 4+ is checked on:
    in reply to: Dead band for data #822
    Hi Gerrit,
    I think deadband is useful for exporting to an external DB, because DB may become a bottle neck. Rapid SCADA itself is fast and deadband is not very important.
    I’d like to improve the Export DB module in the future. I’ve written this idea in the internal tracker.
    Also you can variate a delay after polling in SCADA-Communicator to decrease a volume of information.
    in reply to: Dead band for data #820
    I’m looking forward to receiving news from you
    in reply to: Dead band for data #818
    If you mean you need export changes when the difference between the current and the previous values is greater than a deadband (curVal – prevVal > deadband), it is better to use a stored procudure because logic is more complex.
    What is the reason for filtering? If you try to minimize communicating with SQL Server my approach is not suitable for the case.
    in reply to: Dead band for data #817
    I think you should add a filtering condition in SQL script in the export module or create a stored procedure that contains a filter and execute it in the export module.
    Something like this:
    INSERT INTO CnlData (DateTime, CnlNum, Val, Stat)
    VALUES (@dateTime, @cnlNum, @val, @stat)
    WHERE @val > 100 -- filtering
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #813
    Schemes still don’t work on Raspberry. I expect that this working properly in the new version of SCADA-Web, which development will be started soon in February.
    Recently, the support of UTF-8 strings was added. It allows using of various national characters. It hasn’t been published yet. If this functionality is important for you I can send an update.
    Have you complete German translation or it is in progress?
    in reply to: Dynamically display text in a text field #809
    Definetely! Thanks for the clarification 😉
    in reply to: Status information for communication channels #807
    If communication is stopped, status of device channels become Unreliable (5) within 5 minutes by default. In case of communication error channel status is Undefined (0).
    You can visualize this information as needed. Anyway visualization uses input channel data.
    in reply to: Output command value #802
    To avoid setting a command value you can create an output channel with Standard command type, Execute command value and the following formula: BitConverter.ToDouble(new byte[]{0x38,0x08,0,0,0,0,0,0})
    If my formula contains error, please let me know.
    in reply to: Scada Communicator not able to list opc server #800
    Most likely you have to install OPC Core Components.
    You can download them from this page http://rapidscada.org/download-all-files/ (at the bottom of the page).
    in reply to: Output command value #796
    Thanks ) Happy New Year for you!
    I think the most clear way is using Binary type of the output channel. The formula of the channel should return array of bytes: new byte[] {0x38, 0x08}
    May be I’ve made a mistake in this formula, I just tried to show the idea.
