MikhailModeratorIf you receive data from Communicator in the channel 808, you have to turn it to Real channel type.
If the channel type is Real, the formula is calculated only when SCADA-Server receives data from SCADA-Communicator.
So you need to create an additional channel of Calculated Real type that will be quickly response to changes of the channel 768, and it depends on 768 and 808 channels.
MikhailModeratorIf i need to buy a new license for every client, can i charge extra for it(have profit over the license value)? Or the client itself need to buy the license from RapidSCada.org?
Are you planning to offer Software as a Service for you clients? I think we should discuss these in details to create the best offer. Could you describe your vision by email?
Could you explain what ACM is, please?
For now the difference between Home and Business types of licenses is the price only. The reason is that the home automation should cheaper in compare with business purposes in accordance with the customer capabilities.
The existing licenses apply to a one server without limit of connections. Thereby, you need one license for each client.
MikhailModeratorThe one message is not translated…
Please open http://localhost/scada/scheme/ScadaSchemeSvc.svc and tell me what you see?
May be in IIS 6 you need to make some configuration of web services processing.Does Insufficient rights error still occur?
P.S. The new web application is under construction. It will be free of those issues
MikhailModeratorJust install MSSQL Compact from the prerequisites.
You have to execute both:
SSCERuntime_x86-ENU.msi
SSCERuntime_x64-ENU.msi
MikhailModeratorIf you are talking about Modbus protocol, command must be converted to the array of bytes. Using formulas of output channels you can send any array of bytes according to your needs.
Do you use Modbus?
MikhailModeratorAbout Silverlight:
Does the following page works in your IE and Firefox?
https://www.microsoft.com/silverlight/skinning-and-styling/demo/Also try to open Rapid SCADA in Firefox. Does it work in Firefox?
MikhailModeratorHow to communicate the string elements in rapid scada , please send the document for configuration.
Please provide more details in a separate topic. What are you going to implement?
One issue – one topic.
MikhailModeratorOf course you can use DNS.
E.g.,
smtp.gmail.com, port 587
MikhailModeratorFunctionality of sending emails will be added to the default configuration.
You right, the documentation should be improved.The description that you found in the source is shown on Device Libraries tab of Communicator application.
To send emails automatically you need to install and configure Automatic Control Module
Are emails sent successfully for now?
MikhailModeratorThe new web service allows quickly get trial key http://trial.rapidscada.net/
Send me the comuter code by email, and I’ll send you trial keys.
Does that mean, if my Computer crashes and I have to Setup the System new, I have to buy new licenses?
In general, yes. But if you try to set the same network configuration that exists before crash, there is a chance to use the same key.
If you mean to display 2 series (trends), yes. In this case you need Chart Pro Component
If you mean something else, please provide the details.
MikhailModeratorLooking forward to the information about your project 🙂
