However, the alarm still plays the old sound file and not the one configured at in the Modules.
You should ask the module author for the solution. Possibly write to him on GitHub.
By the way, did you restart the Server service?
Eg. alarm should play when channel value is 1 but should but play if it goes to 0.
Create an extra input channel of the calculated type and revert the value:
Val(101) > 0 ? 0 : 1
101 is the number of the source input channel
MikhailModeratorError check tag type:
Receiving data from OPC server failed.
Add the tag manually by specifying its typePlease provide a screenshot.
What error do you get in browser?
MikhailModeratorAlso the Notification Plugin plays sound. But an operator must acknowledge an event to set beeping off.
Open http://demo.rapidscada.net/plugins/Store/Store.aspx and found Sound Alarm Module in the list. Hope it helps.
Install as usual. Then open the web app by http://localhost/Scada/AutoLogin.aspx
Connection settings on the 1st image are not related to database. Don’t mind about them.
You should find ModDBExport.log and ModDBExport.txt in C:\SCADA\ScadaServer\Log and check the error details.
MikhailModeratorDo you mean the main VM with all software installed?
Yes, the main.
> It is not doing this automatically how to we make sure they can communicate???
Please clarify what is going on. Screenshots usually help to understand.
MikhailModeratorScreenshots would clarify the situation.
MikhailModeratorIs it possible that a proper OPC is already installed?
MikhailModeratorAgent is the application of Rapid SCADA. Agent is included in Rapid SCADA 5.7.
When you install Rapid SCADA 5.7, you will connect to VMs from Administrator installed on your workstation PC.
MikhailModeratorasync/await are efficient when you wait for response via some external channel, like network. SetCurData writes to the internal buffer of Communicator, so this approach doesn’t improve performance in this case.
I use a quite rapid device which refreshs at about 50Hz
It’s better to use PLC to collect data fast and then download data as a block.
MikhailModeratorHi Dawn,
I suggest Rapid SCADA 5.7.x
On the 1st VM install all the apps.
On the 2nd and 3rd install Communicator and Agent.As virtual device you can choose Martrikon OPC simulation server or use the included in Rapid SCADA KpSimulator.dll driver.
As I remember, only Chart Pro refreshes chart automatically.
You should try Chart Pro.
MikhailModeratorYou should try poll any addresses using Rapid SCADA. Some devices answer ILLEGAL ADDRESS, but others return correct response filling with zeros. If yours of the second type, you can find non zero registers.
