Viewing 15 posts - 3,166 through 3,180 (of 6,289 total)
  • in reply to: Mono high cpu usage #8504
    Interesting. Reloading the entire web server just to start new log…
    Does the new approach stop reloading?
    in reply to: Scan Time #8503
    You need to specify a pulse length and polling rate. And make sure that polling rate is fast enough to detect a pulse.
    in reply to: MQTT Sub String #8496
    Currently the MQTT driver doesn’t support string values. To support strings, update is required.
    Also Rapid SCADA version 5 has a limitation of max. 8 Latin characters in tag. Is 8 characters enough for you?
    What kind of string values do you need to read?
    in reply to: Mono high cpu usage #8494
    What’s the proper way to have a client showing the scada page 7×24?
    It depends more on web server. For example, by default Windows IIS restarts application pool every certain period. It’s possible to disable restarting.
    I haven’t heart that Apache also restarts something. Anyway, after web app restart, you will see break lines (——–) in ScadaWeb.log and then
    2021-02-21 00:00:42 <opticalsensing><www-data><ACT> Initialize common web application data
    How regular such text is in the log?
    in reply to: Mono high cpu usage #8493
    I disabled chart plotting and hide minute data export. So there should be one or more cause other than these 2.
    Good idea.
    I am going to make a program to monitor the cpu usage by mono, try if I can capture what cause the issue.
    Probably there should be utilities to read CPU load, provide by SNMP and read by Rapid SCADA.
    in reply to: about SCADA V6 #8492
    His email is below this article.
    i have write some kpdrivers moddrivers. how can i put it on website and sell it?
    Are they ready for other users? I mean tested and contain manual?
    Could you provide description of the modules?
    It’s possible to publish them to the repository after some validating. Please create new topics to discuss the modules. It’s better, a topic for each module.
    in reply to: Additional calculation triggering #8491
    in reply to: Send command #8490
    OK
    Sorry, I mean Generator.
    I don’t see Channel in the list
    You can type any channel number.
    in reply to: Mono high cpu usage #8481
    Note: Mono may work incorrectly if you open the web app by local browser and also open it remotely by IP address. It’s better to use Linux without GIU.
    in reply to: Mono high cpu usage #8480
    I faced that Mono hangs after heavy operation like opening a chart for a long period.
    We will get rid of Mono and move to .NET5.
    Can you reproduce CPU load?
    in reply to: Mono high cpu usage #8479
    Will it effect scada if I kill the www-data PID?
    Server and Communicator continue work. So you can try killing the process.
    First, try restarting Apache by restart_apache.sh
    Error getting events by the filter where channels= , view id=1:
    Scada.ScadaException: User not logged on.
    JavaScript on a client page requests for data, but user is logged out. This is not a cause likely.
    Usually when user is logged out, he is redirected to Login.aspx automatically. For some reason he was not redirected. To stop this error, a user should close a webpage or navigate to another page.
    in reply to: about SCADA V6 #8477
    May be there should be a tool to export a project to RDBMS. This would be very useful for complex systems and different integrations.
    in reply to: about SCADA V6 #8476
    i have done much work on rapid scada.
    i really love it.
    Appreciated 🙂
    in reply to: about SCADA V6 #8475
    i am going to write a vue.js project to handle all config file and save them in my own db by .Net5 backend
    What DBMS will you choose?
