Viewing 15 posts - 1,171 through 1,185 (of 6,282 total)
  • in reply to: Error while trying to add an OPC Classic device #14336
    May be you need to install OPC Core Components (available on our website).
    Also, you should configure access rights in DCOM settings, which can work unpredictable.
    OPC DA does not need to specify TCP port.
    Consider installing the Communicator service on the same machine as OPC server. Communicator can send data to SCADA-Server remotely. And configuration may be simplified.
    in reply to: Custom Page #14325
    The examples were added. Check this link.
    Is it possible to reproduce the problem?
    in reply to: Linux Installation – OPC-DA XML #14323
    The existing OPC DA driver (DrvOpcClassic.dll) does not support the OPC XML DA standard.
    In my opinion, OPC XML DA is a transition standard between OPC DA and OPC UA, so the standard too rare to implement its support.
    A timestamp of the event is set by the Server service when the event is created.
    A timestamp of the data point may be changed according to the archive writing period. It depends on the archive properties.
    in reply to: How to write value and appear on the screen? #14319
    Channel 46804 is not needed.
    In the channel 46805 the output formula is just SetData()
    The above should work, see https://ibb.co/KqvK15r
    in reply to: Convert historical data from V5 to V6 #14318
    > migrate all the *.dat files (in v6 format already) into Postgresql database
    Currently, there is no ready to use converter. 2 approaches come to my mind:
    1. We can develop a converter by a contract.
    2. Deploy an additional instance of Rapid SCADA and use Rapid Gate module to transfer data from the additional instance to the main instance of Rapid SCADA.
    in reply to: Convert historical data from V5 to V6 #14317
    > decided to use PostgreSql as only one achieve as main achieve
    It’s up to you. However, why don’t you use *.dat format as a secondary to make the system more reliable?
    in reply to: Rapid SCADA IoT #14312
    Could you draw a simple diagram that shows the architecture of your system?
    in reply to: Convert historical data from V5 to V6 #14311
    2) In Elastic Report, use SelectArchive and/or DefaultArchive
    3) Yes. Activate archives that are in use.
    in reply to: Convert historical data from V5 to V6 #14310
    1) Create a copy of ChartPro.xml, for example, PlgChartPro_Profile2.xml
    Add a new line into ChartPro_Config.xml
    <Profile fileName="PlgChartPro_Profile2.xml">Profile 2</Profile>
    in reply to: How to write value and appear on the screen? #14305
    To allow a user setting a channel value, create a channel of the Calculated/Output type, and set it’s output formula to SetData()
    DynamicText will show the current value of the channel.
    in reply to: Convert historical data from V5 to V6 #14304
    > Those .dat files from v5 I used the converter to convert to v6 .dat files format, can be trend by modArcBasic only, right?
    Yes.
    > what should I do after I set ModArcPostgreSql as my main achieve and still can trend back those converted historical data previously from v5?
    Using Chart Pro, you can create a chart profile to open data from *.dat archive. Reports also support choosing an archive.
    However, may be in your case it is better to use PostgreSQL as a secondary archive.
    in reply to: Convert historical data from V5 to V6 #14299
    Try the updated converter. Send a screenshot of its work, please.
    in reply to: Current Data sudden become Not Ready #14298
    That’s good! Thank you for the info.
