It looks like something wrong with the web application. If you start the Scada website in the IIS management console, what happens next?
As a first step, try writing historical data to the future using ScadaTestClient.
If data successfully saved and displayed, then we can think how to read them by a driver.-
This reply was modified 2 months, 2 weeks ago by
MikhailModeratorTry changing channel values by ScadaTestClient in order to test triggers separately.
MikhailModeratorNote that a trigger fires when a channel value changes. I mean that the trigger condition should be false, and after that the condition should be true to cause the trigger to fire. Did it happen?
If the channel is undefined, the trigger condition neither true or false as I remember.
If the channel is specified, the object is redundant here.
According the above part of the log, the fallback trigger does not fire.March 23, 2026 at 12:28 pm in reply to: Help with Remote Access to Webstation (External Devices) #17779
The most safe way is creating a virtual machine in the cloud, install Rapid SCADA there, and upload data from your local system to the cloud system by Rapid Gate Module.
Allowing external access to local resources as described above is possible, but risky.
MikhailModeratorFor the output channel 208 set the event flag to generate events on commands. It can help to see what value was sent and when.
SetVal is wrong in that function. The function used in the output formula shouldn’t set any channel, it just returns a value.
Check ModAutoControl.log to make sure that commands are sent when needed.
In the Administrator app, Tools – Project Tools – Encrypt Password
Note that the encryption is not for the Users table, because the table contains hashes (not passwords).
Thank you for the update.
Such credentials are located in ScadaInstanceConfig.xml
It is possible to setup the archive to use other login/password, but in most cases it is more convenient to set them in that single file.
MikhailModeratorThe channel should be tied to the relay or something.
Try the following approach:
1. Add a command under the trigger with the 180 sec delay.
2. That command is sent to a new channel of the output type.
3. In the output formula of the channel, check the condition and reject a command if the condition is not satisified.Example of output formula:
CheckCondition() ? CmdVal : double.NaN
MikhailModeratorPlease create a new topic for the different question.
My question is about what exactly these channels represent.
In your project, open the Channels table by double-clicking it. The Administrator application shows the number of records in the table. This is the channel number mentioned by Rapid SCADA Standard license.
Also, how many channels are included by default in the standard Rapid SCADA installation?
Community edition has no limits. Channel limit is applied only to the additional modules. If the number of channels exceeded, a commercial module stops working, while the main services continue operating.
If you need more variables, you can expand the exiting license of the same type by paying only a price difference.
Be free to ask more questions.
You should enable password auth for user ‘postgres’ by editing the PostgreSQL configuration files and executing some SQL commands. This is the typical issue. Try googling it. -
