Help with Remote Access to Webstation (External Devices)
Forum Home › Forums › Communicating with Devices › Help with Remote Access to Webstation (External Devices)
  • #17776
    Ekrem
    Hi everyone,
    I need help accessing the Rapid SCADA Webstation from external devices like my mobile phone or other computers.
    Current Status:
    Webstation works fine on the host machine via http://localhost/scada/.
    I cannot access it from other devices or different networks using the server’s IP address.
    My Goal:
    I want to allow users to log in with a username and password from any device (mobile/PC) to view specific tables/dashboards.
    #17777
    Do you have a router? To log in from the outside, you need to configure port forwarding on your PC with a web server port 80 or 10008, depending on your settings. A static external IP address is required, which the router will receive.
    You may also need to configure the firewall.
    #17779
    The most safe way is creating a virtual machine in the cloud, install Rapid SCADA there, and upload data from your local system to the cloud system by Rapid Gate Module.
    Allowing external access to local resources as described above is possible, but risky.
