MikhailModeratorHi Dejan,
Your configuration seems correct. In the new version of SCADA-Communicator commands are displayed on the Device Data page. What is the command value there?
MikhailModeratorDouble click your device in the tree of SCADA-Communicator.
Then add element to Write data folder.
After restarting Communicator try to send command on Commands page of the device.
Does the default configuration with MatrikonOPC Server for Simulation work correctly?
I’ll send you the module today evening.
MikhailModeratorCurrently v4.5 is in the develop branch
Now it is stable and can be downloaded.
The module version 4.5 is ready, but not published yet. I can send it by e-mail.
This module is not free that is why there is no its sources on GitHub.
The specified cost of licence applied to a one computer. If you are going to purchase a large number of licenses, discount is possible.
At this time I’m not ready to share the source even for a money. If you need some improvements, we can discuss it.
In most cases update is free. It could be payable if the module functionality significantly increases. DLL update is necessary, if SCADA-Server API changes.
MikhailModeratorThe general sequence:
1. Create one output channel with Command number = 1 and Command values = Off-On
It allows to send 0 – off, 1 – on2. Using the module add 2 Command Triggers.
The 1st fires on 0 value of command 1. The 2nd fires on 1 value of command 1.3. Create a one new command under the each trigger with the required command numbers.
If you have already updated Rapid SCADA to version 4.5, please, let me know for sending you the module update.
Each output channel is bound to the only one command number. In your case you are going to send different commands using the single output channel. It is possible with help of Automatic Control Module
Download the trial and try to realize how it works. If help is needed, write here.
I’m sure, it is possible, but hasn’t be done before. If you’d like to do it, I’ll try to help you.
MikhailModeratorIt seems like problems in the equipment.
MikhailModeratorProbably, something wrong in WCF. If you have an opportunity to chack on another computer, please do it.
MikhailModeratorFress F12, then go to Console and try to find the errors )
MikhailModerator“Specified cast is not valid” is fixed.
I need more info about auto update issues. Could you provide the info?
MikhailModeratorSeems that problems are in the USB adapter or the wires. If you connect this adapter to Windows computer, does it work correctly?
MikhailModerator1. ScadaSetup.exe is fixed. It does not affect work of the applications.
2. There is a bug, but I can’t reproduce it. If you know how to do it, please write. Send me C:\SCADA\ScadaWeb\log\ScadaWeb.log please -
