Viewing 15 posts - 5,731 through 5,745 (of 6,275 total)
  • in reply to: RPi as a TCP server, Local PC as a client #1413
    You need sending commands to a device. First of all, try to send them manually.
    For automatic control you need this module.
    in reply to: Modbus RTU addressing issue #1410
    If Use SCADA-Server checkbox is set on and communication line is bound to server in Communicator settings, the device address is taken from the configuration database (SCADA-Administrator). You can validate that address is actual in SCADA-Server -> Files -> Configuration database -> kp.dat
    After editing and passing the database restart Communicator.
    in reply to: RPi as a TCP server, Local PC as a client #1408
    You have to change communication channel properties in Communicator and set Master behavior. Do you poll your devices from the PC and need to send collected data to RPi?
    in reply to: New Web App Idea? #1406
    Schemes were quite slow to design
    Definitely 🙂
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #1404
    If you use Wonderware InTouch, why you ask on Rapid SCADA forum?
    in reply to: New Web App Idea? #1402
    Tables with ~100 channels is slower to draw
    How much slower? Could you post network tab of Chrome and requests timing?
    schemes not used
    Do you mean you don’t use schemes?
    in reply to: New Web App Idea? #1400
    It includes charts but without scaling and ChartList. The ChartPro and ChartList components should be redesigned to make them fit for tablets.
    in reply to: New Web App Idea? #1398
    Charts have been added.
    in reply to: Slave id in ModDBExport #1397
    Input channel number fully identifies data. If you need device number, you should create additional table in your MySQL database which defines the relations between channel numbers and devices.
    in reply to: Mismatch values in scada server and communicator #1395
    Open SCADA-Administrator and look for the formulas of these input channels.
    in reply to: Unable to load http://localhost/scada #1390
    Also, you can try the prototype of the new web app: http://forum.rapidscada.org/?topic=new-web-app-idea&paged=2#post-1362
    in reply to: Export to excel and Table view #1389
    To export the table view and events find a button with Excel icon on the main page of the web app (Main.aspx). To export minute data goto to reports page (Report.aspx) and choose Minute data report.
    in reply to: Unable to load http://localhost/scada #1388
    IIS seems OK.
    Did you install Rapid SCADA in C:\SCADA\ScadaWeb folder?
    Please check if the folder C:\SCADA\ScadaWeb exists and contains any files.
    If the folder doesn’t exists, try to reinstall SCADA-Web.
    in reply to: How to modify many database fields content easily? #1385
    The great approach! I think it should be included in the SCADA-Server shell.
    in reply to: PLC data in flat files. #1384
    Please, send me an email request. The address is here.
    Also provide the following info:
    1. What kind of data should be written in files:
    – current data sent by devices,
    – historical data,
    – events?
    2. How to clean the outdated data?
    3. What is the due date?
    4. Any additional requirements?
