In the last screenshot the role is Disabled. But in Users table the user Test has TestRole. Are all of these happen at the same moment?
MikhailModeratorYou should be careful, because if user has rights to all views, he can view events, get charts and reports for all the data, event if some views are not shown in the tree.
MikhailModeratorNote. Create topics for new issues, please. This thread has become too long. The new web app is coming very soon.
MikhailModeratorIssue 2. Interesting case. Thanks!
This option exists for advanced users.1. Go to WebSettings.xml
2. Set ViewsFromBase to false
3. Specify view tree in ViewSettings.xml
It has the new format in SCADA-Web 5 and edited manually in a text editor.
MikhailModeratorIssue 1. You have to grant access to “folders” which are separate records in Interface table.
If it doesn’t help, post screenshots of the tables, please.
1. Add a new channel of the type Calculated Real.
2. Enter a formula such as Val(1) + Val(2) and switch it on by the checkbox.
3. Pass the configuration to Server and restart Server service.
MikhailModeratorAlso Chart Pro for the new web app is ready.
And the new plugin Elastic Report, which allows to generate almost any form of report.
If need them, please let me know (they are not published yet).
It is done )) Download the beta again.
Most likely, the official release will be in November 2016.
You can easily display a date on a scheme by putting the parts close to each other.
But dates can be shown separately in a table view for now.
It is planned to add date and time format to Rapid SCADA. I hope, in this year or till the next spring. If the issue is critical, you are welcome to sponsor this feature to get it fast 🙂
MikhailModeratorThe formula will be
Cnl/1000; CorrectStat()
MikhailModeratorAlso you can add items to the configuration file manually and watch whether it works or not.
File path: C:\SCADA\ScadaComm\Config\KpOpc_XXX.xml
MikhailModeratorThere are few similar questions:
1st
2nd
3rdI think, you should try tuning DCOM configuration. How to open the config is described at the end of the article.
MikhailModeratorPlease, provide your value of the formula field of the input channel.
Does this error appear for any folder of the OPC server?
Could you try the same with Matrikon.OPC.Simulation server?
MikhailModeratorDoes it work for the current time?
