Viewing 15 posts - 5,536 through 5,550 (of 6,287 total)
  • in reply to: Change Text of dynamic text element by fomular #1879
    For example, -; Alarm; Armed; Disarmed; Fired; Normal
    – equals 0,
    Alarm equals 1,
    Armed equals 2,
    etc.
    in reply to: Change Text of dynamic text element by fomular #1878
    See this guide page 6. I hope we will create new documentation system soon.
    You can create formulas in Formulas table for reusing, and you can define any number of strings, not only Opened and Closed.
    in reply to: Change Text of dynamic text element by fomular #1876
    Yes.
    1. Create a new input channel number 4 (number must be greater than existings) of type Calculated discrete.
    2. Create a record in Units table for “Opened and Closed”. See No-Yes as an example.
    3. Set Formula field for the new input channel. Something like
    Val(1)>0 && Val(2)<=0 && Val(3)<=0 ? 1 : 0
    4. Set Unit field for the new input channel to your unit that you just created.
    5. Set Format field to Text.
    in reply to: SNMP #1873
    Please contact me by the email. I can send you my Skype ID.
    in reply to: Read data from MySQL #1870
    You should develop or purchase a driver that implements required functionality and “knows” the model of your database. Driver is a DLL written in C#. See this article http://rapidscada.org/device-drivers-development/
    • This reply was modified 9 years, 5 months ago by Mikhail.
    in reply to: Visual Studio #1867
    I think the cause is Windows Communication Foundation (WCF) problem. Check WCF checkboxes as shown in “Rapid SCADA. Before installation. Switch Windows XX features on” video of the playlist.
    in reply to: SNMP #1865
    I think, we will implement the required functionality sooner or later. It is not included in the plan for now, but in case of some commercial interest, we can arrange it.
    The technical limits:
    – ASCII encoding
    – max. length is 8 characters
    Is it OK for you?
    in reply to: SNMP #1863
    In case of errors, please create a separate topic.
    in reply to: SNMP #1862
    Also you must update KpSnmp.dll
    in reply to: SNMP #1860
    1. Create input channels for string tags.
    2. Create such formula in Formulas table (not tested):
    int GetStrNum()
      byte[] buf = BitConverter.GetBytes(Cnl);
      string s = Encoding.Default.GetString(buf);
      if (s == "MyVal1") // your string values
        return 1;
      else if (s == "MyVal2")
        return 2;
      else
        return 0;
    3. Create your own record into Unit table. Use the units 36 and 37 as examples.
    4. Enter GetStrNum() in formula field of input channels, change channel type to Discrete and change format to Text.
    Please write about the result.
    in reply to: Error on the web browser #1857
    It usually happens if WCF for .NET Framework 4+ is not installed. See this video
    in reply to: SNMP #1854
    I mean, you should know all the possible values of the strings.
    in reply to: SNMP #1853
    Currently, only predefined strings from enumerations are supported. You can’t display custom string as values of input channels of Rapid SCADA. If your strings can be specified in enumeration, I can provide the details how to configure Rapid SCADA. Otherwise, if you are able to receive the strings and display them on your own web page, you can embed this page into the web application of Rapid SCADA.
    in reply to: OPC v2.0 can get tags but NOT values #1850
    Thank you Young for so kind words 🙂
    Merry Christmas!
    in reply to: OPC v2.0 can get tags but NOT values #1848
    Dear Young,
    Thank you for the research.
    I have an idea:
    1. Copy ScadaCommMono.exe from Rapid SCADA for Linux installation package to C:\SCADA\ScadaComm\
    2. Run it instead of the service.
    This is the same Communicator but works as a console app.
    Does it work with your OPC server?
