manjey73ParticipantIf we are talking about the xlsx you can write a driver. The data format is nothing but an archived set of xml files. And search xml a realistic goal. If this is the old format it will be more difficult.
manjey73ParticipantStandard command in control channels in Administrator settings-control Lines
The command input window will be called. Using formulas, you can make a range from which the minimum or maximum value of the range will be sent when an input error occurs
manjey73Participanthttps://www.schneider-electric.ru/ru/faqs/FA334611/
Read the document carefully. The voltage starts from the register 3020, it may be necessary to add to the registers +1, that is, to start with 3021
Since there is no register between 3018 and 3020, you get an error from the device
This reply was modified 7 years, 11 months ago by
manjey73.
manjey73ParticipantA link to the list of registers PM2100. Perhaps when prompted in RapidScada need to specify the address of the register + 1
manjey73ParticipantYes, they can if they are not hardware-specific (such as GPIO management on a Raspberry)
manjey73ParticipantBriefly here https://rapidscada.org/device-drivers-development/ for english
Also use the source code of the project and the source code of the drivers from the users. MQTT Driver, Raspberry PI 3 Driver and others. Links can be found under http://demo.rapidscada.net/plugins/Store/Store.aspx
manjey73ParticipantBetter yet, if you get the udev rules then you will be able to name your USB-RS485 e.g. /dev/mydev/COM1 and not to pay attention that reboots it may be ttyUSB1 instead of ttyUSB0
manjey73Participantyes
manjey73ParticipantYou need to implement Modbus slave device on Arduino
manjey73ParticipantI used a relay Board that is controlled by a minus. Therefore, for convenience, I’ve done inversion of control commands and control. If you use this fee-free formulas then 0 will turn relay 1 off relay
manjey73ParticipantAfter you have configured the Communicator and transferred the data to the Raspberry Pi and rebooted scadacomm, you will see the kpXXX file in the folder ScadaComm\log.txt, which you have attached to GPIO channels.In it you will see the table included with the numbering of gpio signals. Use this numbering in the input and control channels
manjey73ParticipantI created channels manually, because this mechanism is not implemented in the driver, if I can judge correctly.
manjey73Participant
manjey73ParticipantYou must set the checkboxes to change direction to OUT. On the idea of under such a a combination of will are engaged physical contacts 3 and 5
