Viewing 15 posts - 841 through 855 (of 921 total)
  • in reply to: General Configuration Sequence #3837
    The Server and Communicator are started in minimized mode, locate from the system tray
    in reply to: M-Bus #3833
    Hope just for those who have devices with m-Bus. At least it is planned to make free drivers that work with a specific device on the logs of requests and responses of the device. It is not difficult, as little changes there.
    in reply to: M-Bus #3831
    There is also a problem with scanning devices, not all manufacturers lay this functionality. For example, Wesser Heat Meter does not have this functionality and does not even have an address provided by the Protocol. It has only ID and only it can be used to run a survey.
    in reply to: M-Bus #3830
    Sorry for my English, I use online translator
    Thanks for the links. But the problem I have is not with the description of the Protocol, and with real data from the devices. The Protocol gives a greater freedom of choice of data transmission, which of them will choose the manufacturer only knows. I would like to see different types of data transmission from different manufacturers. At the moment I have only two devices and both transmit Variable data Structure.
    At the moment I have implemented the processing of Variable Data Structure in the response.
    in reply to: CRC Error #3814
    01 03 30 00 00 08 4B 0C
    So it became clear that any online calculator Modbus CRC in the calculation of CRC along with it should give the result 0
    AI 0-20, 4-20 mA
    It was necessary to buy such a module, there is a description in English and you can check the information on the Protocol and the method of calculation of channels.
    • This reply was modified 7 years, 10 months ago by manjey73.
    in reply to: CRC Error #3812
    Write to the Chinese that they have the wrong byte sequence in the CRC. Well, if it does not help, you can try to build KpModbus.dll in the new version, where you change the sequence of bytes for CRC, and to call it KpErrorModbus.dll 🙂
    in reply to: CRC Error #3809
    http://modbus.rapidscada.net
    Probably your device is not quite standard. If you use the specified link and check your request, the CRC is correct, the lower byte forward, according to the Modbus Protocol.
    https://www.lammertbies.nl/comm/info/crc-calculation.html
    Online Calc shows just the CRC value as it is.
    I would like to look at this device that does not send CRC Modbus younger byte forward, I have never seen this in the factory products.
    in reply to: Trying to communicate with Chinese 8IN8OUT device #3805
    Programm
    The link at the bottom has links to but in Chinese. There will be question marks instead of characters
    in reply to: Trying to communicate with Chinese 8IN8OUT device #3803
    Check if this Board has a WEB interface ?
    in reply to: Trying to communicate with Chinese 8IN8OUT device #3801
    The description indicates that the relay must be sent ON1 to be switched on. I can assume that this is the name of the button but the screens Chinese characters. Write to the sellers of this Board, or follow the links, maybe they have this program in English. If I’m right, then put this program you can use the tracking programs and see what are the parcels in the Protocol.
    The Chinese may be deceiving, saying that there Modbus TCP. I was afraid to buy a Board without a description in my time. I chose the one where the list of registers for management was given.
    in reply to: Trying to communicate with Chinese 8IN8OUT device #3793
    Given the Ethernet module used, it can be assumed that there is no Modbus TCP but Modbus RTU on top of TCP. It is a relay not come across live.
    in reply to: Trying to communicate with Chinese 8IN8OUT device #3791
    Give a link to the device you purchased on AliExpress
    When connecting via RTU, you are informed that the address does not match
    in reply to: Trying to communicate with Chinese 8IN8OUT device #3789
    What exactly do you use from the Chinese site ?
    On AliExpress was not a description of the registers ?
    in reply to: How to send value #3780
    screen1
    screen2
    screen3
    screen4
    In the input channel, specify the output channel number, in the output channel, configure the Standard command. You can also add a formula if necessary, without adding a formula additional actions are not required. Sorry, but my test system is in Russian.
    On the website in addition to the documentation seems to be the video lessons, well, you just have to try different options.
    in reply to: How to send value #3778
    CmdVal, Cmd double The command value transmitted to Server before calculation
    http://doc.rapidscada.net/content/en/software-configuration/using-formulas.html
