manjey73Participantoutput channel – SetVal(43,Cmd)
input channel 43 – Val(43) and in table “output channel” set 43, channel is Calculated
manjey73ParticipantOnly for the initial installation and migration of driver libraries, for example. Edit the Instance name and key for the Agent. Otherwise, the project is transferred using the Agent from Windows to Linux without problems.
WinSCP and SSH connection are enough to copy and install files.
manjey73ParticipantI do not know how advanced it is, it is better of course to use third-party applications for organizing RAM disk, which independently saves data to disk. Unlike tmpfs, as there are some limitations.
For example var stuffed into tmpfs does not allow xrdp to run
manjey73Participant1st input channel use the formula – LoadRet()
Channels that require saving – Retain(Val(43))
Retain(here there can be a formula that returns necessarily double)In the last channel, the formula – SaveRet()
65535 use the formula – SaveRet()Any solution can lose value during a hard reboot, but if the variables do not change often, then you can use different options.
This reply was modified 5 years, 3 months ago by
manjey73.
manjey73ParticipantRetain Formula for writing a variable to a file retain.txt
string pathRet = @"/opt/scada/ScadaServer/Config/retain.txt"; Dictionary<int, double> DictRet = new Dictionary<int, double>(); public double Retain (double ret) { DictRet[CnlNum] = ret; return ret; }Example of applying the formula in the input channel database. Retain(Val(150))
The control channel can contain setval(150, Cmd)The lowest input channel uses the load_retain formula
Recording in the loadret channel()bool initRet = false; double LoadRet() { if (!initRet) { if (System.IO.File.Exists(pathRet)) { string[] RetLoad = System.IO.File.ReadAllLines(pathRet, Encoding.UTF8); for (int i = 0; i < RetLoad.Length; i++) { SetVal(Convert.ToInt32(RetLoad[i].Substring(RetLoad[i].IndexOf("[")+1, RetLoad[i].IndexOf(", ")-(RetLoad[i].IndexOf("[")+1)),10),Convert.ToDouble(RetLoad[i].Substring(RetLoad[i].IndexOf(", ")+2,RetLoad[i].IndexOf("]")-(RetLoad[i].IndexOf(", ")+2)))); } initRet = true; } } return Convert.ToDouble(initRet); }Executed once at server startup
The most recent channel uses the save_retain formula
Entry in the saveret channel formula()double SaveRet() { string[] RetSave = new string[DictRet.Count]; bool eq = false; for (int i = 0; i < DictRet.Count; i++) { RetSave[i] = Convert.ToString(System.Linq.Enumerable.ElementAt(DictRet, i)); } if (!System.IO.File.Exists(pathRet)) { System.IO.File.WriteAllLines(pathRet, RetSave, Encoding.UTF8); return 0; } else { string[] RetOld = System.IO.File.ReadAllLines(pathRet, Encoding.UTF8); eq = System.Linq.Enumerable.SequenceEqual(RetOld, RetSave); if (!eq) { System.IO.File.WriteAllLines(pathRet, RetSave, Encoding.UTF8); } } return Convert.ToDouble(eq); }The path to Raspberry specify your own in the first formula.
An example file retain.txt[450, 23]
[451, 51]
[452, 51,5]
[453, 46]The first digit is the channel number, the second is the channel value.
The file is written when the variable specified as Retain is changed.
You can also initialize the necessary variables when starting the server.For changing variables in the process of work, but which need to be saved, it is better to add probably another timer and record no more than x minutes. I think so.
For configuration variables that rarely change, you can use as-is.
manjey73ParticipantOn Raspberry, I used formulas to save and read channel data to a file. Since the values fall into RAM (tmpfs)
manjey73ParticipantНасколько знаю, это доступно только пользовательским командам протокола, которых нет в драйвере. Так что не совсем ясен сам вопрос ?
з.ы. а почему на английском сайте ?
manjey73ParticipantRedirection was enabled by the site owner on the apache stub page, so it shouldn’t happen by itself 🙂
manjey73ParticipantThis means that when we open the root of the site, the Apache page should open and not jump to the internal site. It is not clear why this is happening ?
manjey73ParticipantThank you, it works. But there are nuances 🙂 For example, if you write the root of the site mysite.com then there is a redirect from the apache page that should not be, is there any way to fix it ?
http://mysite.com:8084/scada/Login.aspx
I used port 8084. Michael needlessly removed the settings for mono-xsp4 from the installation description file for the mono version
manjey73.
manjey73ParticipantMaybe the address is not 5 ? And this address is listed in the documentation as an example, if the device has an address of 5 ? Or maybe someone changed the address in the device ? The same baud, parity, bit depth ?
manjey73ParticipantChanged it to Port 23 and no difference. ????
You have a different port specified in the Ethernet settings-RS485 and it must be specified in the communication line settings. It is the one that is registered as Local Port Number and not 502 or 23 by default
In this case, the Modbus device settings should be as for RTU mode-TransMode = RTU
manjey73ParticipantHave you tried connecting to the device via USB-RS485 ?
manjey73ParticipantTry reading just one register first and make sure they are readable. and only then add registers to the query group
manjey73Participant
