manjey73ParticipantYou can get a temporary computer code for testing, and you need to pay for the code that will work in the WEB, if you have a separate server, Web server
manjey73Participant(note: setting of “../Scheme/Scheme. aspx?viewId=35” does not work).
In order for the link to work, you need to add this scheme to the views, give it rights, configure the display as a separate view, then you will know its ID, then you insert this view into another scheme with this link. The ID number will be the one that you will be assigned by the system. To hide this view from the list in the tree, you need to set the”Hide” checkbox
You will still have to create 128 views and hide them, and specify them for frames
manjey73ParticipantDownload and install Extra Component Cheme.
Activate it. Place the Frame component on the main diagram and specify the Address in its properties –../Scheme/Scheme. aspx?viewId=35where the viewId number corresponds to your view number. In the view settings, if necessary, set the checkbox to the hidden position.
manjey73ParticipantThe frame is located in the extended components of the schemas. But I’m trying to figure out the link myself now, I don’t know how to do it correctly.
manjey73ParticipantOops, try using a frame from additional circuit components. I somehow did not try to put one mnemonic into another…
manjey73ParticipantI use online translation for English and it is unlikely that I will be able to help with the help of messengers.
When you have created the schema in the administrator, right-click-Open the location in Explorer.
Make a copy of the file there and re-open the project in the administrator. You will see a new scheme, open it for editing and change the channel binding. This is path number 1.
The way number 2 is to use offset for channels for an already drawn mnemonic scheme.
Create Offset
manjey73Participant1. Copy the file to the Interfaces folder. Open a new file with the editor and change the channel bindings.
2. If the channels are strictly sequential, you can refer to the same mnemonic scheme and specify the channel offset in the database settings-Interfaces
manjey73ParticipantAnd why did you upload the file? The question is what does it lie in?
manjey73ParticipantTry version 5.8.3 there were changes regarding PostGre if I’m not mistaken. Only use the Modbus driver from version 5.8.2 (some error there)
manjey73ParticipantThe entire mnemonic scheme is copied as a whole file with the renaming of the last one. And you can also call the same mnemonic circuit and specify the channel offset in the interface, like the example was in the documentation. But this is strictly for typed mnemonic circuits. Or what exactly is it about ?
manjey73ParticipantIf the RS232 port uses additional signals other than Rx and Tx, then cheap converters will not work. To do this, you need to have a connection diagram. The RS485 interface can also be soldered on the DB9 port, but again, you need to have a diagram of the interfaces of your PLC. It is worth contacting the seller of this equipment.
manjey73ParticipantНапишите мне на почту, найдете в информации драйвера.
Я пришлю свои выделенные IP (рабочий и домашний)
manjey73ParticipantIEC62056-21 кажется это обновление протокола 61107, надо будет поизучать и попробовать на живом приборе.
manjey73ParticipantПо описанию на ACE6000 у него не 61107 а DLMS/COSEM
manjey73Participant@Yatran сможете организовать удаленный доступ к приборам для тестирования?
И есть ли на них документация производителя о типах запросов и логи например с OPC сервера или перехваченные логгером порта в текстовом и HEX виде ?
На русском форуме тоже тема есть.
This reply was modified 4 years, 9 months ago by
manjey73.
