Viewing 15 posts - 226 through 240 (of 923 total)
  • in reply to: HTTP Error 404.0 – Not Found #15952
    Do you have the version 2 module for IIS installed?
    Well, you have installed the necessary component for the WEB from ASP.NET ?
    in reply to: No sign-in #15950
    The administrator account allows you to send commands and sees all the views.
    in reply to: HTTP Error 404.0 – Not Found #15949
    in version 6, you don’t need to write /scada
    or just localhost or specifying the default port 10008
    in reply to: No sign-in #15945
    Do I set up autologin in the SacadWeb instance settings?
    in reply to: Daily Data #15943
    https://ibb.co/8290Y5J
    By default, the table takes data from a minute archive, perhaps choosing an archive will help in this case.
    You also need to set up Graph calls for this archive.
    • This reply was modified 1 year, 3 months ago by manjey73.
    in reply to: How to know the network connection status of a device #15929
    Sorry – For the Divice – service Tag code – Status
    in reply to: How to know the network connection status of a device #15926
    For the user, this is the service code of the tag – Status
    Create a channel with this tag code.
    Where the value 0 = Normal, 1 = Error
    There is no equivalent for Communication Lines in the current version yet, if I’m not mistaken.
    in reply to: InitScripts() use #15916
    Just create your own formula in the script table, in which you can initialize any variables.
    I was doing something similar to version 5 to simulate non-volatile variables through files.
    In a simple version, it looks like this
    bool initVal = false;
    public double InitValues()
    if (!initVal)
    SetData(1153, 0, 1);
    SetData(1154, 0, 1);
    SetData(1155, 0, 1);
    SetVal(1031, 0);
    SetVal(1032, 1);
    initVal = true;
    return Convert.ToDouble(initVal);
    And most importantly, place the channel with the call of this formula at the very first in the channel database.
    Moreover, the formulas in the channels themselves can be any.
    in reply to: InitScripts() use #15915
    I checked, there are no errors during compilation, but it seems to me that you are trying to use an internal formula even before the server starts processing formula data. Most likely InitScripts is intended for other things.
    in reply to: InitScripts() use #15914
    If you look at CalcEngine.cs, then InitScripts() goes first and only then SetData.
    When the server is started, this code is compiled every time.
    Using SetData inside Initscripts, do you encounter any errors?
    in reply to: InitScripts() use #15913
    Perhaps InitScripts() is intended for other things. And at this point, formulas like setData may not be valid yet.
    in reply to: InitScripts() use #15912
    Explain for which types of channels do you want to set the values to 0 when the server starts?
    Show the settings of these channels
    in reply to: Formul #15910
    Commas are most likely a number separator display format related to the OS regional settings.
    in reply to: Formul #15907
    If this is the input channel from the device, you need to use Cnl/10
    Cnl, CnlVal double Channel value transmitted to Server before the calculation
    Script documentation
    in reply to: InitScripts() use #15904
    I may be wrong, but it seems enough to specify Val() in the input formula and SetVal(CnlNum, Cmd) in the output, and when the Server starts, the channel will be 0.0, and after entering your value
    For Calculated/Output channels
