HTTP Error 404.0 – Not Found
Forum Home › Forums › Communicating with Devices › HTTP Error 404.0 – Not Found
  • #15946
    Elnaz.zare
    Hello
    unfortunately i cannot connected to Rapid SCADA successfully. When i Enter http://localhost/SCADA i faced with HTTP Error 404.0 – Not Found . if you have any suggestion please guide me because it is nessessory to connect successfully.
    #15949
    in version 6, you don’t need to write /scada
    or just localhost or specifying the default port 10008
    #15951
    Elnaz.zare
    First of all i want to say thank you for your response
    when i just write localhost i see the welcome page of IIS
    and when i enter http://localhost:10008/ I faced with HTTP Error 500.19 – Internal Server Error(IIS 10.0 detailed error)
    #15952
    Do you have the version 2 module for IIS installed?
    Well, you have installed the necessary component for the WEB from ASP.NET ?
    #15954
    Elnaz.zare
    could you please list the necessary component that i have to install or cheak them?
    #15955
    IIS runtime support (ASP.NET Core Module v2) Check that the module is installed
    You need a Hosting Bundle
    and
    .NET Runtime 8.0.11
    #15958
    Link
