Viewing 15 posts - 166 through 180 (of 923 total)
  • in reply to: about mod develop #16495
    It seems that the fact that the Server sends a command does not guarantee that the device executes the command. For example, an erroneous value that the device will not accept.
    It is necessary to wait for feedback from the device driver.
    in reply to: information of the Archive #16489
    You need to replace the used dll files from the current version of Scada in the utilities
    in reply to: Cannot Show Full Text on Web Browser #16468
    I’m afraid nothing will help here. Charts, reports, they operate channels. And here is an array of channels that contains the full text.
    What is it for? maybe just operate with numeric values and display text through enumeration ?
    in reply to: Get Application Error when use “Chang period” #16466
    You will need to re-request the keys for version 6 on the same PC.
    • This reply was modified 10 months, 2 weeks ago by manjey73.
    in reply to: Cannot Show Full Text on Web Browser #16458
    ChartPro are not designed to work with text arrays of channels.
    in reply to: Cannot Show Full Text on Web Browser #16452
    Because you write the first 8 bytes of Ascii into each cell.
    The SplitAscii formula must be applied
    SplitAscii(()=> CheckModeSelectText())
    in reply to: Add calculated channels to OPC UA Server #16438
    Nobody bothers to loop the data, right? In version 6, Modbus slave (paid) allows you to create variables based on calculated channels. We configure the Modbus slave, then the Modbus master on itself. And voila, you get the data source for OPC UA.
    The same option can probably be done with MQTT.
    in reply to: Beckhoff TwinCAT 2 Driver (RS v6) #16433
    I connected to a real PLC on WinCE, and the owner of the installation from the PLC went remotely to the PLC and added the IP of the computer from which we connected to the allowed ones. Without this, it is impossible to connect to a PLC. These are security measures. If you don’t have this option, you probably won’t be able to connect to your PLC.
    in reply to: Beckhoff TwinCAT 2 Driver (RS v6) #16432
    You can try to poll the driver without the *.tpy file. Create an empty template, specify the NetID and port. As far as I know, it is necessary to allow connection to the controller through the administrative means of the controller so that the scada is in the allowed IP addresses.
    Next, set up a PLC Scan and start the line.
    Some series of controllers store a symbolic configuration inside the controller, others will simply output a list of variables without a symbolic configuration. We’ll figure it out next.
    You can also install the Twin Cat 2 Engineering version on your PC and try searching for your PLC to determine its NetID.
    in reply to: Beckhoff TwinCAT 2 Driver (RS v6) #16429
    @hatien If you have a program for Beckhoff in TwinCAT, please send the *.tpy file from your project.
    in reply to: Beckhoff TwinCAT 2 Driver (RS v6) #16427
    @hatien
    It is necessary to try, I had access to only one controller on Windows CE (I do not remember the series). If the controller uses a library from TwinCAT 2 – TwinCatAds.dll that’s quite possible.
    The library has been rewritten on NET6.
    Unfortunately, I do not know C++ to refine the library from Beckhoff in order to be able to use it in the driver code. At the moment, they have a library only for Linux X86 architecture and does not allow it to be used from C# code.
    If you need a key for testing, write to me and I will provide it.
    • This reply was modified 10 months, 4 weeks ago by manjey73.
    in reply to: modbus与lora网关通信 #16412
    If applied to a gateway in Modbus, isn’t the gateway configurable and places the values from each specific device in a specific register? The same probably applies to MQTT, each variable has its own subscription ID.
    You create several d Rapid Scada devices, with their own variables, even the same tags, etc. if necessary (the same tags are allowed in different devices)
    , Place them on the same communication line for the gateway. You set up a survey template for each device.
    It would probably be a little slower if it were a single “Gateway 1” device, but probably more correct.
    in reply to: modbus与lora网关通信 #16408
    Or are your devices still lora?
    And do you want to apply a modbus gateway to them, which you will then poll?
    • This reply was modified 11 months ago by manjey73.
    in reply to: modbus与lora网关通信 #16407
    If the devices are modbus, just poll them less frequently by setting the appropriate period.
    Lora is not supported in Scada.
    in reply to: covert channel #16396
    By disabling the Activity, you exclude the channel from the database.
    As far as I understand, it is impossible to hide a channel from the web table with a value of 0.
    You can overlay a dynamic image on the mnemonic with a transparent background at a value of >0 and the main background of the mnemonic at a value of = 0.
