Viewing 15 posts - 1,471 through 1,485 (of 6,239 total)
  • in reply to: Webstation v.6.1.x #13411
    If you don’t change the Webstation configuration, untick the associated checkbox to avoid unnecessary start/stop actions.
    in reply to: Webstation v.6.1.x #13410
    You can find commands in SCADA\ScadaWeb\*.bat
    in reply to: Webstation v.6.1.x #13409
    You right. On Windows, IIS manages the web application. While on Linux there is a service for ScadaWeb.
    The Administrator app sends a command to IIS to restart. Sometimes it takes a long. Even if you run the same command from a command line, the result would be the same. For now, I have no idea how to fix that programmatically. As for me, I open IIS management console and restart the web app using it. There is no delay in this way.
    This issue presents only on Windows.
    in reply to: Migrating V5.84 projects to V6 #13408
    Why isn’t “ScadaInstanceConfig.xml” file shown as a “child” object in the “Administrator” application’s GUI
    Because ScadaInstanceConfig.xml is not a part of a user’s project. It’s possible to develop an extension that provides UI for editing ScadaInstanceConfig.xml.
    in reply to: Multiple Levels of View Folders #13407
    Do you mean creating nested folders in the View Explorer tree?
    in reply to: Dashboard Plug Issue Using xml File #13406
    Thank you 🙂
    in reply to: Dashboard Plug Issue Using xml File #13389
    In the Views table you should set the view type for the record with ID=7.
    Tables and schemes are detected by their file extension, while dashboards use common extension XML.
    in reply to: Dashboard Plug Issue Using xml File #13386
    I also cannot open the screenshots. Please check.
    Links in the 2nd message work.
    • This reply was modified 2 years, 7 months ago by Mikhail.
    in reply to: Don’t display some events #13375
    According to the settings, events should be generated when channel status has changed. Does the channel status change when you change channel value from -1 to 1, for example?
    Next time, please make screenshots in English.
    in reply to: Channel with Self Increase / Decrease Value #13374
    Automatic Control Module works in this way. It can send command when condition is met. According to the command, channel value can be simply increased.
    in reply to: Channel with Self Increase / Decrease Value #13373
    You need an additional variable to store a flag that the condition change has already processed. After adding 1, set the flag ON. When the condition becomes false, set the flag to OFF. The formula is not very simple, because it executes in a loop as written above.
    Alternatively, you could increase a channel inside the formula of the condition if it’s applicable.
    in reply to: How to use a c# script to process input XML/MQTT message #13372
    in reply to: How to use a c# script to process input XML/MQTT message #13371
    Also you need to specify subitems.
    in reply to: How to use a c# script to process input XML/MQTT message #13370
    If you need to use JS to extract values from JSON, set JavaScript enabled = Yes (in device properties). Create a js file, put it in the Communicator configuration. Specify the file name in the JavaScript file name property.
    in reply to: Installing Licensed Plugins in v.6.1 Beta #13369
    Please create a new topic to discuss configuration of the Dashboard plugin. Provide links to screenshots of your settings.
